VideoHelp.com Forum
    I recently had my DVD Recorder replaced on maintenance with a new one. The new one is an LG LRH-880 and it's remote won't work my TV, so I've bought a universal remote. Unfortunately, I cannot find the remote code for the LG LRH-880. Does anyone happen to know what the code would be, or where I can go to find out?
    TIA,
  2. Member Krispy Kritter's Avatar
    Your best bet would be to contact the remote manufacturer or check their website.
    Otherwise, I would return it and get a remote with better hardware support such as the Logitech Harmony series. There are various models with support for most IR based hardware and if it isn't supported, the remotes have learning capabilities.
    Google is your Friend
    Thanks. I did that, and they weren't very helpful.
    I think I'll have to get another remote...
  1. Remote code for Memorex MVD2016 needed
    By ravenswd in forum Newbie / General discussions
    Last Post: 23rd Feb 2011, 16:47
  2. LG LRH-880 remote control model number needed
    By RGC in forum DVD & Blu-ray Recorders
    Last Post: 27th Aug 2008, 21:23
  3. LG LRH-780 remote control model number needed
    By gm3317 in forum DVD & Blu-ray Recorders
    Last Post: 27th Aug 2008, 21:20
  4. Questoin ... LG LRH-880 HDD Upgrade Possible ?????
    By White_Hair in forum DVD & Blu-ray Recorders
    Last Post: 21st Feb 2008, 18:30
  5. VLC Player - Code Needed For Remote
    By John_Jordan in forum Programming
    Last Post: 15th Jan 2008, 21:13
