VideoHelp.com Forum
    Hello,
    I am trying to convert an HD movies that is in MKV to MP4 so that I can view it on the Playstation 3. However, I have tried things like Gotsent, Ripbot and even my own trick. But they all fail to do it. The file is in 2 parts, I had them both on DVD's for quite a long time. The 2nd part converted just fine, but not the 1st part of the video.
    When I try using Gotsent, it tries to adjust the headers and I get the error couldn't find SegmentInfo. I tried getting it to convert to mpeg2, but that did not work either, ffmpeg just crashes saying FFMPEG Conversion error! no output created.
    I tried to use MKVExtract to extract the audio and video so I can put them into MP4 container but it would not work. MKVExtract would extract a total of 42mb of file, includes both audio and video.
    If I use Media Player Classic to play the video, it works fine, I tried checking the whole video by skipping every few minutes, it never crashes when playing the video. So I don't know where the problem is, the video is viewable using Media Classic player, but I can't extract the audio and video.
    I was thinking I might just decide to convert to an mpeg file, is it possible to do so without harming the quality of the video? is it possible to get that stupid raw video & audio out of that stupid MKV container??
    Could you post the video and audio codecs in the mkv? Identify the mkv with mediainfo.
    You could also try mkv2vob and the vob should work on the ps3.
    But if the mkv is broken you might not be able to convert it. You could try avisynth together with directshowsource() and reconver in some tool.
  1. MkvТоMp4 v0.220a - rapid tool for repack Mkv to Mp4
    By oreons in forum Video Conversion
    Last Post: 24th May 2012, 12:37
  2. MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
    By Baldrick in forum Newbie / General discussions
    Last Post: 2nd Mar 2012, 15:25
  3. MKV to MP4 audio stretch issues!!!
    By wphill in forum Video Conversion
    Last Post: 15th May 2011, 03:30
  4. mkv to mp4(ps3) subtitle issues
    By HeroSmero in forum Video Conversion
    Last Post: 3rd Jan 2010, 19:43
  5. Fixing audio sync issues when using GOTSent to convert MKV to MP4
    By darrklight1138 in forum Newbie / General discussions
    Last Post: 20th Apr 2009, 06:56
