VideoHelp.com Forum
    I downloaded the most recent version of Subtitle Workshop and the Hide timing is grayed out. The help file says you are able to edit the Hide timing. Is there an option to enable it? I've just been subtracting the time where I want the subtitle to hide and entering the duration into the Duration field or making the changes to the .srt file in Notepad.
  2. Member AlanHK's Avatar
    On the left you see some settings:
    Mode:
    Input FPS:
    FPS:
    Work with:
    _ Duration
    _ Final Time
    _ Both
    You must have a check next to "Duration"
    If you check "Both" you can edit either final time or duration.
    Thanks.
  1. Subtitle Workshop Not Playing "Some" Videos
    By timmer545 in forum Subtitle
    Last Post: 7th Mar 2012, 01:27
  2. "Hide" field locked in Subtitle Workshop
    By neuroxik in forum Subtitle
    Last Post: 17th Aug 2011, 02:08
  3. Replies: 0
    Last Post: 12th Jun 2011, 13:34
  4. Replies: 12
    Last Post: 24th Mar 2010, 20:50
  5. DVD5 played by WinDVD and PowerDVD doesnt show "Hide subtitle" op
    By rsb in forum Newbie / General discussions
    Last Post: 22nd Mar 2009, 08:11
