VideoHelp.com Forum
    I try to convert MPEG4 to MPEG-TS using ffmpegX 0.0.9 on my Mac (OS X 10.5.1). I get an error message with an OK button only saying "DIV16_KEY". Does anyone know what this means? I have attached a screen shot.
    Your help is highly appreciated.
    Dirk
  2. Explorer Case's Avatar
    The width of the output should be divisible by 16 for the encoder.
    Possibly you've set a preset before opening the source file? Try the other way around: first set your source file, then set a preset.
    With the MPEG-TS preset, it should default to 720x576 for PAL (25 fps) framerate, and those width and height make a valid frame size.
  1. Help. Avisynth Error Message "no function named limitedsharpen"
    By Pitorasilo in forum Video Conversion
    Last Post: 27th Dec 2010, 06:13
  2. Replies: 1
    Last Post: 8th Nov 2010, 14:58
  3. Help. Avisynth Error Message "no function named deblock"
    By hypnoticpimp in forum Video Conversion
    Last Post: 27th Sep 2008, 23:45
  4. DVD Flick error message "ffmpeg.exe has stopped working"
    By stewiegriffin711 in forum Authoring (DVD)
    Last Post: 17th Aug 2008, 07:20
  5. Replies: 1
    Last Post: 27th Jun 2007, 01:16
