VideoHelp.com Forum
  1. Member iMacMan's Avatar
    I'm new to the HD scene but have recently seen a bunch of these .mkv files floating around.
    I already have my iMac connected via VGA to my my Plasma HD TV and know how to convert/burn/play them
    using VisualHub,Toast,VLC etc... But what I want to know is there something more I can do to get the quality as
    good as an original Blu-ray/HD DVD to view or play on my HD TV via .mkv?
  2. Member iMacMan's Avatar
    That's what I thought.... Nothing yet....
    Looks great as is but you never know?
    mkv is best quality just try and find the 1080 movies. You can play them of course with VLC
  4. Member iMacMan's Avatar
    Thank You Vintage
  5. Member iMacMan's Avatar
    Actually I'm finding very little difference in quality from 720 to 1080.
    Also, 720 plays smoother and is considerably smaller in size (GB).
    Almost every 1080p movie that is about 5 GB has been downsized when looking at bitrate, so you'll never get the Blu-ray/HD DVD quality when downloading a pirate HD-movie. If you want REAL HD you should download the 1080p MKV's that are about 30 GB. But that usually takes a while.
    Aim for 720 in VLC/Mplayer/QT instead.
  7. Member iMacMan's Avatar
    frosse,
    That's why I say "720 plays better than 1080 and is less filling".
    1080 is a HUGE waste of space and time at this point until you can burn 30GB to backup your Blu-ray HD DVD's.
    Anyways, DVD's - HD DVD's etc are on their way out as most people are and will be able to watch anything they
    want via Apple TV etc... Therefore, same old shit different year.
    Yes you can EP6000P
    you can stream MKVto it from your iMAC or simply plug an USB drive with MKV content to it.
    But if you are playing with ripped Bluray then, a new receiver 7.1 is recommended .... you will have 7.1 surround sound via HDMI
    But if you want to convert to MKV then you can use HandBrake... this is very good and easy to use.
    FireWire2
  1. Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
    By brad350 in forum Newbie / General discussions
    Last Post: 21st Apr 2012, 04:15
  2. Can I use MKV Files to burn on Blu-Ray?
    By PHNeedsHelp in forum Authoring (Blu-ray)
    Last Post: 22nd Mar 2012, 02:10
  3. MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
    By Baldrick in forum Newbie / General discussions
    Last Post: 2nd Mar 2012, 15:25
  4. Need help to convert Blu-ray MKV 1080 x264 Video files
    By AndreL in forum Blu-ray Ripping
    Last Post: 18th Jul 2011, 16:04
  5. mkv, x264, and h.264 to blu-ray to play on PS3
    By cyberpimp16 in forum Authoring (Blu-ray)
    Last Post: 14th May 2009, 14:58
