VideoHelp.com Forum
    I'll try to make this as simple as possible. I connected my Philips 3575 into my Dish Network box with a S-video and standard audio cables. I then ran an HDMI cable to my TV. Everything was working great for a few days, I even recorded several programs and successfully played them back. However, today I go to record a show and it records nothing but a black screen!!! When I switch to my HDD mode it's completely blank, however I can still hear the audio. The most confusing part is that I can see my program guide from my satellite and flip around, but the image in the corner is black.
    I've tried everything I can think of. I tried a different S-video cable, I've tried searching through the menus of both the 3575 and my satellite box, and I can't figure out what's wrong. I even took it back to Wal-Mart and exchanged it for a new one, but the same thing is happening.
    PLEASE HELP!!!!!!
    Sounds like maybe the Video > Video Input has been changed to Video In, but should be on S-Video In. That's one possible cause for hearing audio but seeing no video?
    The default is Video In (Composite) so that could be changed with any kind of Reset procedure, or just by accident.
    I've thought about that. I checked and it's still on S-video. Like I said, the part that's really confusing me is that I can see my program guide from the satellite box when I bring it up, it just has a black screen in the corner.
  4. Member Krispy Kritter's Avatar
    Seeing the program guide would be an indication that a video signal is passing from the SAT box to the recorder. The "black screen in the corner" would be where the current broadcast should be displayed. So although the SAT box is sending video to the recorder, it no longer appears to be sending the broadcast video. The only channels that may not be viewable, would possibly be pay channels (HBO/Showtime/Pay-Per-View).
    Either way, it sounds like something has changed in the SAT box. Either a setup change, software update/change or hardware failure.
    Google is your Friend
    Thanks everyone. The problem was my satellite box. I powered it down manually and let it reboot and it fixed the problem.
  1. Philips 3575/3576 and Magnavox H2160 Features, Setup and Operation
    By wabjxo in forum DVD & Blu-ray Recorders
    Last Post: 10th Mar 2009, 14:55
  2. Philips 3575 refurbs at Ubid.com $219.99 w/free shipping
    By KeepItSimple in forum DVD & Blu-ray Recorders
    Last Post: 22nd Jul 2008, 20:57
  3. Philips 3575 + Restoration = fails tests
    By lordsmurf in forum DVD & Blu-ray Recorders
    Last Post: 24th Jan 2008, 11:55
  4. Philips 3575 -- Why don't different Titles appear as different VOB files?
    Last Post: 12th Jan 2008, 18:11
  5. Philips 3575 or JVC DR-MV5s?
    Last Post: 31st Dec 2007, 05:53
