As title...what tools would i need to do this. Wanna keep as close to the original dvd quality as possible but as an xvid or avi.
Thanks.
Well you need to rip the DVD so the most obvious choice would be DVDFab HD Decrypter.Originally Posted by coolchris
For the DVD to AVI conversion the most popular tools are autoGK and avi.NET
Also the makers of avi.NET make a program called pgc.NET which is very useful even if you decide to just use autoGK instead (which often times is the better choice than avi.NET).
Basically DVDFab HD Decrypter rips the DVD into file mode. You then use pgc.NET to re-rip the section you want from the DVD (be it the main movie or a particular episode if it is an episodic type DVD etc.) then use autoGK or avi.NET to do the AVI conversion.
Both will allow you to keep the original AC-3 audio or convert to MP3 format.
Anyway to convert MKV DTS to AC3 5.1 surround sound?
By Patsfan37 in forum AudioReplies: 5Last Post: 31st Dec 2011, 08:02 -
Burn a AVI file w/ AC3 to DVD and get the surround on it?
By WBFAir in forum DVD RippingReplies: 4Last Post: 31st Oct 2011, 14:07 -
DVD to AVI with surround sound
By Sutekh in forum Blu-ray RippingReplies: 1Last Post: 12th Aug 2009, 12:47 -
By Sutekh in forum Newbie / General discussionsReplies: 1Last Post: 12th Aug 2009, 12:46 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 08:44
Statistics
Newest guides
Latest tool updates
New media comments
