VideoHelp.com Forum
Results 1 to 13 of 13
  1. I have a program that takes way to long called dvd flick it takes like three hours to convert to DVD is there a faster program? I don't want a menu either.
    http://www.technologyforever.com/video1.html
    Video hosting and video sharing community
    http://www.technologyforever.com/game1.html
    free online games
    ConvertXtoDVD is faster, and will give you about 90% of the quality of DVD Flick.
    WinAVI is faster again, and will give you around 70% of the quality and will crash a lot.
    If you seriously want to speed up your encoding, spend some money, get a quad core intel CPU, and you can use FAVC to produce a DVD in under 30 minutes. I can.
    Bottom line, speed and quality rarely go together when it comes to encoding. Only raw grunt will give you real speed improvements and keep quality acceptable.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Member mats.hogberg's Avatar
    And as always: The fastest way is not to convert at all, but get a DVD player that also plays DivX/XviD AVI. The cost is the same as most commercial "allinone AVI to DVD" offerings.
    /Mats
    Hey, let me ask you guys a couple of questions about ConvertXtoDVD.
    1) If I have an MKV that has IDX/Sub subs, can I import it into ConvertXtoDVD and the subs show while playing on the DVD player or would I still have to use an OCR program to convert the IDX/Sub and then import it into ConvertXtoDVD.
    2) Does ConvertXtoDVD work with Avisynth scripts?
  5. Member mats.hogberg's Avatar
    From the developers site:
    Handles subtitles files (.SRT .SUB/IDX .SSA) with color and font selection, and supports tags (italic, bold)
    You may have to demux it tho. And yes, convertx2dvd can read AviSynth scripts.
    /Mats
    /Mats
    Yeah, I knew I would have to demux it, but I didn't know if ConvertXToDVD would accept them.
    Also, you may or may not know this, but do MKVs that use IDX always come with a .sub file or can you have one without the other?
    Thanks in advance
  7. Member mats.hogberg's Avatar
    There can be sub subtitle files on their own, but then it's a text based sub. The kind of sub that usually go together with a idx is pretty useless without the idx, just as idx is pointless without the sub. Basically, the sub contains the images for the subtitles, the idx is information on when to show what image from the sub.
    /Mats
    /Mats
    Thanks for the response.
    Spent a few minutes fooling around with ConvertXToDVD.
    I got stream errors, which I am assuming it was the audio, which is OGG.
    I was also confused on which file, the IDX or the SUB to drag into the Stream Portion but I saw that it didn't matter which one, as it does the same thing. What is cool is that if you demux the IDX/SUB files, it will automatically add them to the stream list.
    I am sure I will have more questions but I am at work and it is impossible to judge the software one way or another.
    too much I think for a Quad
    I have friends of mine with Quads which had sent me this pictures
    http://img207.imageshack.us/img207/6...dspeed1ge5.jpg
    http://img522.imageshack.us/img522/9...dspeed2mj3.jpg
    130.000 frames in about 8 minutes is much better, with CCE...they didn't tried HCEnc
    I have a regular Dual Core Notebook, very poor, it takes about 40m to encode, or 1 H
  10. Always Watching guns1inger's Avatar
    Creating a DVD is more than just video encoding. That time includes applying pulldown, encoding audio, muxing and authoring. I get encoding speeds of 125 - 140 fps on average with HCEnc.
  11. Member AlanHK's Avatar
    If you're really in a hurry, HCEnc, which is normally a two-pass encoder, can be set to one pass "constant quantization" (on Settings 1 page). The size of the output file is unpredictable then, but it takes about half the time and quality is still good.
  12. Always Watching guns1inger's Avatar
    FAVC uses a Predictive Quant mode that hits the right size and can also split the file and process in sections for separate cores. At the moment this is faster than letting HCEnc do it's own thread management.
  1. Fastest program to convert AVI to MP4?
    By thecalip in forum Video Conversion
    Last Post: 27th Jun 2011, 18:54
  2. fastest way to convert avi to iphone/ipod?
    By videdit in forum Portable Video
    Last Post: 2nd Nov 2010, 05:04
  3. Best/Fastest way to easily convert a dvd (.VOB) to .avi
    By xxnonamexx in forum DVD Ripping
    Last Post: 4th Sep 2010, 12:17
  4. Replies: 5
    Last Post: 13th Sep 2009, 02:54
  5. Fastest AVI to DVD program
    By mjaeson in forum Authoring (DVD)
    Last Post: 18th May 2007, 05:09
