VideoHelp.com Forum
Results 1 to 9 of 9
  1. hi, i've .mkv videos and demuxed it, now i want to convert it to xvid+ac3, which converter should i use and if i don't change the quality settings (keep %100) what about video quality?
    dogano
    Unless your demuxed .mkv stream has and xvid encoded video stream (i.e not AVC/h.264), it is impossible to keep 100% quality when re-encoding using a lossy codec.
  3. so how can i play it on a claasic dvd-divx player?
    dogano
    You can convert it to a format that your standalone player supports, but be aware you will lose some quality. There are many, many posts on how to do this, just use the search function. If you have any more questions after that, there are many people here that could help you
    Good luck!
    Hi.
    This will do the job. Takes MKV as input. May want to try a few different recodes. I tried with HCEnc 0.22 and it looked pretty good.
    AVStoDVD 1.2.1 (2007-12-08 05:40)
    Find out first what format the video is in. It may already be Xvid or DivX and need no converting.
    Try GSpot or AVIcodec or mediainfo to find out
    I have very successfuly converted mkv to avi/xvid with Winavi. It looked as good as the original & played without a problem in my standalone. An hour & a half film took about 30 minutes to convert with my system & I didn't have to diddle around demuxing and all that other crap. Sometimes the easy way just works. You don't know till you try it.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Try also alltoavi.
  9. Always Watching guns1inger's Avatar
    Although I have found alltoAVI's output is not standalone compatible in all cases.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  1. MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
    By Baldrick in forum Newbie / General discussions
    Last Post: 2nd Mar 2012, 15:25
  2. mkv[x264] to mkv[xvid] conversion
    By killerhex in forum Video Conversion
    Last Post: 17th Nov 2010, 01:41
  3. Best quality option to convert 1080p mkv to 720p mkv
    By carlmart in forum Video Conversion
    Last Post: 14th Mar 2010, 07:17
  4. Replies: 11
    Last Post: 21st Jan 2010, 22:07
  5. VFR MKV to XVID MKV
    By Shaorin in forum Newbie / General discussions
    Last Post: 24th Nov 2007, 01:52
