VideoHelp.com Forum
    I was reading a review of the Pioneer DVR-115, DVD Burner and came upon this statement: "One notable exception, however, was the missing connection for Digital Audio playback."
    How do you get the sound if you cannot connect the audio wire? I hope this guy is dead wrong, as I have purchased one from Newegg.
  2. Member hech54's Avatar
    I haven't needed any extra audio connections(of any kind) from my drives since my old Packard Hell computer....10 years ago?
    You need to connect a redbook cable to your sound card to get sound. My Plextor has it and all other drives I seen have it. I see now, he says "Digital Audio", this is not the 4 pin red book audio which it must have.
  4. Cable has not been required for several years. Audio now moves through the data connector.
    AC-3, 2 and 5-channel, from files and DVD, as well as audio CD, play perfectly with no redbook audio connector whatsoever. SPDIF passthru or straight to speakers. Only thing I have not tried would be a SACD, but SFAIK no difference here, either.
  5. Get Slack disturbed1's Avatar
    That is only for analog audio playback. You can press play on the DVD/CD drive and have it come through your sound card with out using a player. As stated above, it's old technology, not really needed anymore, since all recent audio players (made after Win98) can play and extract using the data interface.
    Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
    Since there is no way to play the SACD disc layer on a PC, the only way to play SACDs on PCs is to play the audio CD compatibility layer, if the disc has it. In this case the disc is treated exactly as a normal audio CD and the SACD layer is completely ignored. So you can't really try SACD.
  7. Mod Neophyte Super Moderator redwudz's Avatar
    pepegot1, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
    Try to choose a subject that describes your topic.
    Please do not use topic subjects like Help me!!! or Problems.
    Thanks,
    Moderator redwudz
  1. Splitting an RCA audio connection
    By coolxal in forum DVD & Blu-ray Players
    Last Post: 3rd May 2012, 12:36
  2. Replies: 0
    Last Post: 25th Oct 2009, 10:47
  3. Western Digital HD TV Media Centre - Missing audio codec support
    By Hcw87 in forum Media Center PC / MediaCenters
    Last Post: 21st Jul 2009, 13:55
  4. 1080p true hd to 720p true hd possible ?
    By miss in forum Video Conversion
    Last Post: 16th Jul 2009, 21:48
  5. Replies: 3
    Last Post: 29th Apr 2009, 22:48
