Thread: Helmet Cam
    Hi, I'm trying to put together a basic helmet cam set up. I want good quality, but trying to keep costs in check.
    1) What is the key criteria for picking a good bullet camera? Is it the number of TV lines?
    2) Any suggestions on a good video capture device?
    Thanks.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    400 lines or so would be good. I'm assuming color.
    How are you saving the video? Do you need a transmitter and a receiver or a solid state digital video recorder? That adds weight and complications. You may be able to use a video transmitter if the range is short, and a separate video recorder.
    Most basic cameras have a composite output. Do you need audio also? Some have that option, or you can add a microphone.
    The more inexpensive color cameras are called 'board cameras'. Some are mounted on a circuit board and require a simple enclosure. Others have a enclosure.
    Then there is the viewing angle, wide angle or telephoto. You need to know what range of viewing field you want.
    And light sensitivity. Some color cameras need a lot of light, some very little.
    Do you need weatherproof?
    Most cameras need 12VDC, but for short term, you can use a dry cell battery pack, even AA cells.
    This site sells security cameras, but they have a good selection of all types and they are dependable. http://www.supercircuits.com/index.a...S&Category=437
    You can buy cheap helmet cams. But if you want quality and dependability, you need to shop around a bit.
    Get one of these http://cgi.ebay.com/Car-Color-Video-...QQcmdZViewItem
    Dirt cheap, decent quality and in a steel waterproof housing.
  1. Broadcast live helmet cam video to a TV
    By phisherman11 in forum Portable Video
    Last Post: 20th Aug 2008, 14:57
  2. Helmet Cam
    By ctpaddler2000 in forum Newbie / General discussions
    Last Post: 4th Oct 2005, 03:39
  3. Helmet Camera where NOT to buy !!!
    By goat in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 22nd Dec 2004, 23:33
  4. what input socket reqd for helmet cam?
    By rikki in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 27th Feb 2004, 12:45
  5. Sports cam "helmet camera"
    By E-meil in forum Newbie / General discussions
    Last Post: 27th Nov 2001, 04:26
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
