VideoHelp.com Forum
Thread: zune help??
  1. Banned
    My friend just purchased one convert tools,so I could convert some of my favorite DVDs to wmv files for my Zune. I have followed the steps but when I go to my Zune software to add the video file to my Zune, the video doesn't show up. If I browse my computer directly to the folder it was saved in, it's there and it works properly when played. It just isn't allowing me to put the video onto my Zune. It's a wmv file, but will not go on my Zune. What needs to be done here?
    ths
    not all converters work. what one is it you are trying?
    even if it's not in the right format the zune software should offer to convert it and sync it onto the zune.
  3. Banned
    ths,all converted video couldn't sync"( why?
  4. Member Krispy Kritter's Avatar
    If the files play on the Zune, then it sounds like the conversion was successful. It sounds like you have a problem with the Zune software which is likely misconfigured. You would likely get a better answer in a Zune forum.
    Google is your Friend
  5. Banned
    Ths,can you tell me what' s wrong? Krispy
  6. Member Krispy Kritter's Avatar
    I have no idea and I don't have a Zune. But as I stated above, if the Zune can play the files driectly, then there is likely a configuration issue with the software. I'm sure there is a FAQ somewhere that addreses the issue or you could try a Zune specific forum.
    My only suggestion would be to uninstall and reinstall the Zune related software on the PC and to ensure you have all of the latest patches/updates.
  7. Banned
    ths, this problem had been conquered,thanks for all help
  1. Zune HD converter
    By mrvegas777 in forum Video Conversion
    Last Post: 6th Jul 2010, 18:41
  2. zune and h.264
    By jntaylor63 in forum DVD Ripping
    Last Post: 21st Apr 2009, 13:07
  3. Converting to Zune
    By Invader Bugs in forum Video Conversion
    Last Post: 23rd Nov 2008, 12:08
  4. Zune Questions
    By Teh Joke in forum Portable Video
    Last Post: 13th Feb 2008, 06:08
