VideoHelp.com Forum
Results 1 to 9 of 9
    Hello,
    I am a bit amateur when it comes to video editing and I have been asked to edit a video for a friend. The clips I have (that are supposed to be HD?) open in quicktime which tells me the video is : DVCPRO50 720x480 (853 x 480) millions. Data Rate 57.55mbits/s Actual size 853 x 480.
    I have always worked in 720x480 DV so this is new to me and I want to know which Final Cut Pro sequence preference to use while editing so things are not distorted when I export. Also why is it set to 853 x 480? Should it not be either a 4:3 ratio or a 16:9? 853 seems like such a random number.
    The final output of these videos will be compressed down for the web and burnt to a dvd for tv viewing. I want to make sure I set my preferences correctly from the start of this project so that I dont end up at the end with a product I cant use. I am really hoping someone can shed some light on this for me.
    I guess what I really need to know is if 853 x 480 should be set to a preset of 720 x 480 (4:3) or 720 x 480 (16:9) or something totally different. Any advice is welcomed and much appreciated.
  3. Always Watching guns1inger's Avatar
    it is the square pixel representation of 720 x 480 16:9
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Where is this commonly used? Why wouldnt someone either shoot in wide screen or 720 x 480 4:3? If I am to use these clips for editing would I set my file up as 720 x 480 anamorphic? Using Square pixels?
  5. Always Watching guns1inger's Avatar
    Your project would be 720 x 480 Anamorphic (16:9). Don't way about the 853 x 480 reference. That is how it will appear on playback only. You have standard definition footage. It may have come from a pro level camera, but it is definitely SD.
    Could it have been shot in HD and captured in DVCPRO50 format? Or would logic dictate that it was shot and then captured as DVCPRO50 clips.
    Could have been. Quite a few HD cameras will output SD DV over firewire. The original footage may have been HD.
    To correct this would the footage have to been captured using some kind of HD preset? How does one go about making sure HD footage is transfered properly?
  9. aBigMeanie aedipuss's Avatar
    there's a firewire setting in the cam to export HD or SD.
  1. Replies: 4
    Last Post: 7th Apr 2011, 17:24
  2. Replies: 2
    Last Post: 10th Oct 2010, 12:52
  3. Replies: 10
    Last Post: 16th Dec 2008, 23:38
  4. Replies: 2
    Last Post: 16th Jan 2008, 22:49
  5. Replies: 4
    Last Post: 16th Nov 2007, 22:07
