Results 1 to 9 of 9
  1. hello, anybody knows the hack to free the region code of the dvd player COBY TF-DVD7377, I tried using the hacks of all the other similar players but no one works, any suggestions or ideas?
    Thanks,
    Sandra
    All players cannot be made region free. Also, some manufacturers change the firmware on existing player models and that can break hacks that used to work. You may be out of luck here. It's best to do your homework and decide on a player that you are sure can be easily changed to region free mode prior to buying it, rather than buying first and hoping for the best.
  3. Please, there must be someone out there that can help me
    I appreciate your help
  4. Member Krispy Kritter's Avatar
    If there is a known hack, you will find it in the DVD Hacks section. Otherwise, jman98 summed it up pretty well above.
    Google is your Friend
    I just bought this model Coby TF-DVD7377.
    I tried using hack code given in the videohelp site but didn't work.
    Anyone knows if the firmware got upgraded or something...how to hack it now.
    You may be out of luck, sam7777. It's getting almost impossible these days to find players in the USA and Canada that can be made region free. Hollywood has convinced just about everybody to stop making such players. Hacks that used to work in the past may not work now due to changes that manufacturers have made at the request of Hollywood.
  7. Member yumagah's Avatar
    There are several DVD backup programs that will remove the region codes from a copied DVD. This is often a better way to go about playing DVD's with differing region codes. At least if you don't have a large number of them.
  1. Coby DVD-211 Region Hack
    By pabco33 in forum DVD & Blu-ray Players
    Last Post: 23rd Jun 2008, 19:52
  2. Coby tf-dvd3271 Hack
    By roar54 in forum DVD & Blu-ray Players
    Last Post: 7th May 2008, 20:59
  3. Coby-215 DVD player hack do not work
    By van_d_man in forum DVD & Blu-ray Players
    Last Post: 26th May 2004, 17:42
  4. Coby DVD-515 Hack
    By amruo in forum DVD & Blu-ray Players
    Last Post: 2nd Dec 2003, 18:36
  5. Finally the COBY DVD 507 Macrovision hack!
    By nandy16 in forum DVD & Blu-ray Players
    Last Post: 10th Apr 2003, 11:06
About   Advertise   Forum   RSS Feeds   Statistics   Tools
