can someone plz tell me in easy terms what i need to do to make a film more clearer and not so blocky ;seems to be ok on pc is there a way to get a better copy after converting;when the film has black in it its shows the blocks more plz help and thanks as allways.![]()
One world: bitrate. And choose highest quality in Motion Search Setting. But it can't get rid of all the block noise, because the bitrate is only 1150 kb if you are making VCD with TMPG. No matter how hard you try. Your options: a) XVCD b) SVCD with CCE. I recommend latter.
What's a good way to capture online video with good quality?
By newtie in forum CapturingReplies: 4Last Post: 19th Feb 2011, 09:41 -
Where can I buy a good clear (see through) DVD player? Translucent shell
By Daniel_BMS in forum DVD & Blu-ray PlayersReplies: 14Last Post: 3rd Nov 2009, 15:34 -
how good quality is...
By Cazz in forum AudioReplies: 2Last Post: 23rd Jul 2009, 08:23 -
I use TMpgEnc to convert MOV to DIVX. But the quality of AVI isn't good
By natong in forum Video ConversionReplies: 0Last Post: 11th Apr 2009, 00:21 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 03:18
Statistics
Newest guides
Latest tool updates
New media comments
