Hi all.
I have a Magnasonic DVD Player, Model DVD802-2 A. I've had it for a couple of years and it has worked fine but a few weeks back, when I loaded a DVD, it would not play the sound. I've tried it on multiple tvs and switched the component cables and nothing seems to work. I've checked the options in the DVD menu but I haven't found anything that I suspect would be the problem.
Is there anything I can do to fix this? Any help would be most appreciated. Thanks.
Audio does not use the component cables. You need to have separate cables for the audio, either RCA cables (red/white) or use digital outputs (optical or coaxial). Ensure the audio cables are correctly connected and/or try replacing them. The player may also have an audio output option in the audio setup, it should correspond to the type of output you are using.
Google is your Friend
Have a Magnasonic DVD816-4 Player - Bought DVDs "Probhited to play by CSS"
By Butterflyna in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2010, 22:46 -
Converting Magnasonic Dual DVD/VCR player to region free
By JOKER1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Jul 2008, 14:50 -
Sound works on Pc but not on Dvd player
By Rogert in forum AudioReplies: 4Last Post: 7th Jun 2008, 07:22 -
No sound when playing in DVD player
By blizzery in forum AudioReplies: 1Last Post: 28th Jul 2007, 18:35 -
help with no sound with DVD's using Media Player 11.
By Bamahusker in forum Newbie / General discussionsReplies: 6Last Post: 1st Jul 2007, 13:38
