I have a MKV file that plays with sound on my PC but when i convert it to DVD the sound doesnt play on DVD player,
I have tried TWICE and its done it each time, I press the language button on the DVD remote and it tells me the audio is DTS 6ch
but no sound comes out of TV...I would have thought anything in DTS would still play the left right channels...?
is there a way i can change the audio to 2ch before encoding to DVD?
Thanks guys,,,,![]()
Results 1 to 30 of 32
Does your DVD have sound when played on your PC?
/Mats
yes it does, i have another file on the DVD that has 2ch AC sound and that plays..as soon as it trys to play the other file theres no sound...
I encoded 2 MKV files onto 1 DVD structure, one is 2ch AC sound and the other is DTS 6ch, the 2ch plays sound and the other doesnt
The files on the hard drive play sound as does the dvd itself through the laptop...now the laptop doesnt have 6 speakers?? it does have Realtek HD soundchip so may be converting it to 2ch...i dunno
thanks
Many DVD-standalones do not have a built-in DTS-decoder ---
at most they can simply output the DTS-signal to an external
DTS-capable digital amplifier. What is the make and model of your DVD-player?
P.S.:
Yes, you can uncompress the DTS-audio, downmix to stereo, and recompress intois there a way i can change the audio to 2ch before encoding to DVD?
AC3 or MP2. Not a simple task, evidently.
Like Midzuki say. Most players will output only digital signal for DTS and it is up to an amplifier to decode. To be able to play DTS you have to hook up your DVD player through optical or HDMI output. Also your amp has to be able to decode that. Check the manual for it.
my DVD player is just a cheapo BUSH DivX player and doesnt have DTS
the only outputs it has is
SCART
S-VIDEO
VIDEO + 2ch Audio(what im currently using with my HDTV as picture is marginally better than scart)
Coaxial
nothing for DTS or other Audio output and whats more i dont have an amp or soundsystem that i put it through... the dvd-player is hooked upto the TV Audio out-in
A fairly simple way to do this would be to use avidemux
1) Open your mkv in avidemux
2) For the Video sidebar, select 'copy'
3) For the Audio sidebar, select 'AC3 (Aften)', now select your bitrate and in filters choose 'stereo' for mixer - you can also adust the gain etc...
4) Select mkv for format
5) Press save (but you have to type the full filename with extension e.g. "myfile.mkv")
This just stream copies your video, remixes your audio, and places it into a mkv container.
Now proceed with making your DVD as you did before
Cheers
thanks PoisonDeathRay - your a star...
what bitrate do you recommend?
thanks again
oh...its says:
H264 detected
If the file is using bframe as reference, it can lead to crash or stutteting.
Avidemux can use another mode which is safed but YOU WILL LOOSE FRAME ACCURACY.
Do you want to use that mode ?
I clicked OK and it says:
No audio decoder found for this file
Save (A+V) will generate bad AVI. Save audio will work
The sound isnt playing back in Avimux.. and when i try to save it (which i know wont work anyway if it cant decode the DTS it just creates a 1Kb file)
what do you recommend?
Match it to what your DVD authoring program is using (it might re-encode the audio if the bitrate is different - it doesn't really matter)
Otherwise 192 is fairly common for stereo
oh...its says:
H264 detected
I cant understand cos i have AC3 codec installed which plays DTS...
I have
DivX
XviD
FFDShow
K-Lite Codec mega-pack
AC3 Filter
AVIsynth
Quicktime
RealPlayer
Is there anything im missing?
use mediainfo to find out what audio/video your mkv is
By the way, what program are you using to make DVD from mkv?
1) Use MKVExtractGUI to separate audio & video streams
2) Re-Encode your DTS Audio to 2-channel AC3 using Belight/Besweet or some other audio encoder
3) Re-mux your streams with MKVmergeGUI
DTS
6ch
48Khz Sampling rate
no web link
DTS
6ch
48Khz Sampling rate
no web link
Im using VSO ConvertXtoDVD but i do have CCE+AVI2ISO
also I cant find MKVmergeGUI
also when i launch MKVextract it says: MKVextract or MKVmerge not found in the folder please try again?
Ive only got the folder i extracted from the download... this is turning out to be problem after problem
why cant i use AVIdemux?
ive managed to get MKVtoolnix and copy the exe's from that install into the folder, now have the tools, will let you know how i get on...thanks again
I suspect avidemux isn't working because of DTS (It works with AC3). Avidemux is like VLC in that it uses its internal codecs
ConvertXtoDVD resamples all audio to 192kbps AC3 if I'm not mistaken; I wonder why it has a problem with the DTS? You probably could encode the audio to anything, because ConvertXtoDVD re-encodes it anyway
well im trying all these programs and getting nowhere, my desktop is cluttered with folders with these programs in hehe
Belight wouldnt work without Besweet so i got that, put all besweet files in belight folder and conversion creates a 4Kb file...
so i used BeSweet GUI with wizard and when i click GO it just opens notepad and saving it / closing it doesnt make the job start>????
what a nightmare...
yes well ive tried VSO convertXtoDVD twice with the same file and it doesnt change the audio to ac3, it has kept it the same
It seems to have an AUDIO options on AUTOMATIC but its greyed out even with file loaded
I'm not sure why? It could be that you didn't download the aac.enc or aac.exe and place them in the besweet folder.
Another option would be foobar2000 just right click and use "convert"...use something easy like mp3
Unable to open item for playback (Unsupported file format):
"E:\Track2.dts"
FOOBAR.... says above
Try renaming the file extension to .wav
the DTS file?
yes, the dts file
apparently you need a dts plugin for foobar
http://www.hydrogenaudio.org/forums/...hp/t36067.html
http://dtsguide.de.vu/
when i rename it .wav it says:Unable to open item for playback (Unsupported format or corrupted file):
ok eventually got the right dll file hehe
(thanks for your help btw)
it now opens and plays the audio - how do i convert it?
In foobar? Right click => Convert =>Originally Posted by snadge
its now asking for the LAME encoder location?
jees this aint straightforward is it? i been on over 2 hours trying to convert this 1 audio file...
where would it be? i do have it installed im sure along with Fraunhoffer mp3 codec
You might not have LAME installed...either convert it to something else recognizable by convertx, or install LAME
i managed to install LAME again but it still asked, so i located it to the lame.exe i run from the download to install it and its working now...38mins to convert it
thanks... hopefully should mux backtogether ok in MKVmerge is it?
Best Blu Ray Player to play 3D MKV (DTS audio) files off my USB HDD?
By Freaz in forum DVD & Blu-ray PlayersReplies: 18Last Post: 28th Apr 2012, 22:15 -
6CH DTS Channel Order?
By maxeemo in forum AudioReplies: 4Last Post: 14th Apr 2011, 16:58 -
DTS wont play through amp
By Bazza-61 in forum AudioReplies: 11Last Post: 24th Sep 2009, 09:54 -
AVI with DTS wont play - can I convert?
By snadge in forum AudioReplies: 4Last Post: 29th Jul 2009, 09:41 -
Why wont windows media player play any audio from my created dvds
By thnkbg in forum Authoring (DVD)Replies: 1Last Post: 17th Aug 2007, 10:30
