    Hi everyone:
    I have a VHS copy a foreign movie. The VHS copy has the English subtitle and it is full screen.
    Recently, I bought the re-released DVD copy (a legitimate widescreen version); but unfortunately, it has no subtitle. I searched EBay and found pirate copies, but with Spanish & Portuguese subtitles only, no English.
    So I transfered my VHS copy to DVD.
    I used SmartRipper to rip my entire VHS-transfered DVD to a vob file. Then I used VideoRedo to re-encode the vob in MPEG. I had to do that because my Subtitle Workshop cannot decode AC3 (trust me, I already tried to play the vob file with Subtitle Workshop and got no sound).
    Next, I loaded the MPEG file into Subtitle Workshop. The file played just fine and I started "new subtitle" then played the movie. I paused the movie to "insert subtitle" each time a line of subtitle appeared on the screen.
    The whole process is pretty labor intensive and time consuming. Is there any better way to create subtitles from a hard-coded version?
    I feel that I'm perhaps asking for the impossible. But who knows?
  2. Member mats.hogberg's Avatar
    SubRip can (try to) OCR subtitles out of a hard subbed AVI to .srt, so that route may work.
    Chances are tho, that the VHS version and DVD version differ in parts (different cuts) so you'll end up with a subtitle file that doesn't fit your DVD version anyway.
    /Mats
    Thanks, Mat. I'll give it a try. The timing difference between the VHS and the DVD should be taken care of by Subtitle Workshop's Edit. All I need to fix the difference is the times of the first line and the last line.
  4. Member mats.hogberg's Avatar
    Unless there are scenes added/deleted/cut differently between the 2 versions...
    /Mats
    Hi Mat:
    I just succeeded in creating the first line. Wow, the technology of recognizing words by their font color is amazing.
    Thank you for your help.
