Page 1 of 3
1 2 3 LastLast
Results 1 to 30 of 85
  1. Hi,
    So I just added a Samsung SH-S203N (SATA) drive to my box... It reads & rips fine, but every time I tried to burn a ISO file to a DVD, with DVD Decrypter (3.5.4, older free version), the drive just stops responding. The speed and write rate drop to zero, and the process status bar just stays where it's currently at. The program does not lock up and allows you to access it, but the burner just keeps spinning and spinning and spinning.... Even after closing DVD Decrypter.
    After several tries I decided to send it back thinking it was defective. I got a new one and guess what? Well, I then checked the firmware and it already has the lastest version (SB01). Then a relative told me that DVD Decrypter might be "too old" for this new burner and to try NERO, which came only with the 2nd burner (go figure)... Nero burned about 5 DVDs with no problems, some even less than 5 min!
    So I thought for sure my problem was solved, until I tried to play one. It played but was pretty glitchy... So, hoping that the maybe the ISO file was corrupt or something, I tried to burn a different ISO file to DVD with Nero and it F'n froze at 81%, just as it did with DVD Decrypter initially! Again, Nero didn't freeze, but the burner just stopped responding and the process bar stuck at 81% for 10 min, until I finally aborted!
    PLEASE send any suggestions or thoughts b/c I am SO FRUSTRATED - I've never had a problem with burners! Always used NEC and have burned at least 250 DVDs, litterally... Not sure if this matters but, my system still has a NEC burner in it, but it's IDE connection... I just added this new SATA burner and it recognized it fine and set it to drive "H", after the NEC burner which is drive "F" ("G" is for a card reader in my printer).
    Thanks so much in advance!!!
    P.S. Not sure if it helps but here's the Nero burn log when it failed, even though it never actually gave me an error message before I aborted... 1 thing I noticed is that it has "IDE" listed as the adapter type for the Samsung SATA drive????
    Windows XP 5.1
    IA32
    WinAspi: -
    NT-SPTI used
    Nero Version: 7.10.1.2
    Internal Version: 7, 10, 1, 2
    (Nero Express)
    Recorder: <TSSTcorp CDDVDW SH-S203N>Version: SB01 - HA 1 TA 1 - 7.10.1.2
    Adapter driver: <IDE> HA 1
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ?
    CD-ROM: <_NEC DVD_RW ND-3550A >Version: 1.05 - HA 1 TA 0 - 7.10.1.2
    === Scsi-Device-Map ===
    CdRomPeripheral : _NEC DVD_RW ND-3550A atapi Port 0 ID 1 DMA: On
    DiskPeripheral : ST3320620AS iaStor Port 2 ID 0 DMA: On
    DiskPeripheral : ST3320620AS iaStor Port 2 ID 1 DMA: Off
    CdRomPeripheral : TSSTcorp CDDVDW SH-S203N iaStor Port 2 ID 2 DMA: Off
    === CDRom-Device-Map ===
    _NEC DVD_RW ND-3550A F: CdRom0
    TSSTcorp CDDVDW SH-S203N H: CdRom1
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    BUFE : 0
    Physical memory : 2029MB (2078328kB)
    Free physical memory: 1272MB (1303012kB)
    Memory in use : 37 %
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    12.1.2008
    Burn DVD Image
    5:39:09 PM #1 Text 0 File SCSIPTICommands.cpp, Line 424
    LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    5:39:09 PM #2 Text 0 File Burncd.cpp, Line 3508
    Turn on Disc-At-Once, using DVD media
    5:39:09 PM #3 Text 0 File DlgWaitCD.cpp, Line 307
    Last possible write address on media: 2295103 (510:01.28, 4482MB)
    Last address to be written: 2285846 (507:57.71, 4464MB)
    5:39:09 PM #4 Text 0 File DlgWaitCD.cpp, Line 319
    Write in overburning mode: NO (enabled: CD)
    5:39:09 PM #5 Text 0 File DlgWaitCD.cpp, Line 2972
    Recorder: TSSTcorp CDDVDW SH-S203N, Media type: DVD+R
    Disc Manufacturer ID: MBIPG101, Media Type ID: R05, Product revision number: 1
    Disc Application Code: 0, Extended Information Indicators: 7
    5:39:09 PM #6 Text 0 File DlgWaitCD.cpp, Line 493
    >>> Protocol of DlgWaitCD activities: <<<
    5:39:09 PM #7 Text 0 File ThreadedTransferInterface.cpp, Line 793
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660)
    2 indices, index0 (150) not provided
    original disc pos #0 + 2285847 (2285847) = #2285847/507:57.72
    not relocatable, disc pos for caching/writing not required/not required
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2285847 blocks [H: TSSTcorp CDDVDW SH-S203N]
    5:39:09 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 995
    Prepare [H: TSSTcorp CDDVDW SH-S203N] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1: Idx 0 Idx 1 Next Trk
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681414656, ISRC ""
    DAO layout:
    ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
    0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 1 | 0x41 | 2285847 | 2285847 | 0x00
    2285847 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
    5:39:09 PM #9 Text 0 File SCSIPTICommands.cpp, Line 215
    SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
    5:39:09 PM #10 Text 0 File Burncd.cpp, Line 4294
    Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
    5:39:09 PM #11 Phase 24 File dlgbrnst.cpp, Line 1762
    Caching of files started
    5:39:09 PM #12 Text 0 File Burncd.cpp, Line 4413
    Cache writing successful.
    5:39:09 PM #13 Phase 25 File dlgbrnst.cpp, Line 1762
    Caching of files completed
    5:39:09 PM #14 Phase 36 File dlgbrnst.cpp, Line 1762
    Burn process started at 20x (27,700 KB/s)
    5:39:09 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 2721
    Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
    5:39:09 PM #16 Text 0 File Cdrdrv.cpp, Line 9872
    ---- Disc Structure: Physical Format Information (00h) ----
    Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD+R (10), Part Version: 1.0x (1)
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
    Data in Burst Cutting Area (BCA) does not exist
    Disc Application Code: 0 / 0 h
    Extended Information indicators: 7 h
    Media type ID: R05
    Number of Physical format information bytes in use in ADIP up to byte 63: 56
    Media Specific [16..63]:
    00 00 07 4D 42 49 50 47 - 31 30 31 52 30 35 01 38 ...MBIPG101R05.8
    23 54 37 13 02 50 6B 02 - 8C 63 15 15 0B 0B 08 08 #T7..Pk..c......
    01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
    5:39:09 PM #17 Text 0 File Cdrdrv.cpp, Line 9872
    Media type ID: R05
    5:39:09 PM #18 Text 0 File Cdrdrv.cpp, Line 9872
    Media type ID: R05
    5:39:09 PM #19 Text 0 File DVDR.cpp, Line 8376
    Drive: TSSTcorp CDDVDW SH-S203N
    Book Type request [TSST]: DVD-ROM
    Changing the Book Type was finished successfully, return code 0
    5:39:09 PM #20 CDR -1207 File DVDR.cpp, Line 6481
    Book Type automatically set to: DVD-ROM
    5:39:09 PM #21 Text 0 File DVDPlusRW.cpp, Line 675
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    5:39:09 PM #22 Text 0 File ThreadedTransfer.cpp, Line 269
    Pipe memory size 83836800
    5:49:17 PM #23 Phase 40 File dlgbrnst.cpp, Line 1435
    Aborted by user
    5:53:28 PM #24 SPTI -1046 File SCSIPassThrough.cpp, Line 179
    CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1046)
    Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x30
    Sense Qual: 0x06
    CDB Data: 0x5B 01 06 00 00 00 00 00 00 00 00 00
    Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 06
    5:53:28 PM #25 Text 0 File DVDPlusRW.cpp, Line 935
    EndDAO: Last written address 1841472
    5:53:28 PM #26 CDR -1046 File WriterStatus.cpp, Line 162
    Illegal disc
    5:53:28 PM #27 TRANSFER -24 File WriterStatus.cpp, Line 162
    Could not perform end of Disc-at-once
    5:53:28 PM #28 Phase 39 File dlgbrnst.cpp, Line 1762
    Burn process aborted
    5:53:28 PM #29 Text 0 File SCSIPTICommands.cpp, Line 261
    SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
    5:54:05 PM #30 Text 0 File Cdrdrv.cpp, Line 11185
    DriveLocker: UnLockVolume completed
    5:54:05 PM #31 Text 0 File SCSIPTICommands.cpp, Line 424
    UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    Existing drivers:
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    System Specs
    OS:Windows XP
    MB: Intel BOXDG965WHMKR LGA 775 Intel G965 Express ATX
    VGA: EVGA 256-P2-N550 -T2 GeForce 7600GT 256MB 128-bit GDDR3 PCI
    CPU: Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA
    Memory: (2X) Patriot 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Browser:IE
    HD: (2x) Seagate Barracuda ST3320620AS (PRT) 320GB 7200 RPM 16MB
    Sound: Creative Sound Blaster Live! 24 Bit
    PSU: Ultra X2 550-Watt
    Cooling: (2X) 120mm case Fans, stock CPU fan
    Monitor: HP w2207 22" widescreen
    try to get some better media. the Moser Baer India Limited isn't great and may not work in your drive. verbatim -r might give you an idea if the drive is going to work ok.
    also imgburn is the successor to decrypter and you might want to try using it.
  3. Thanks for the reply!
    The media is Memorex 16X DVD+R, and I buy them by the hundreds and have only experienced maybe 2 or so coasters in about 250 burns with my NEC burner... I guess you could be write but I'd hate to change media just b/c of samsung being picky... Thing is, I didn't buy another NEC b/c I heard their quality has dropped... Boy, I hope all new burners aren't this picky and unreliable
    the bar can stop when the drive tries to re-write a bad sector and never succeeds. check over at cdfreaks i'm sure they have a thread about the 203 and what medium is working.
  5. DVD Ninja budz's Avatar
    1wheelken: What brand is your motherboard? Because some sata controller chipsets don't work correctly with SATA DVD Burners. Motherboards with the Intel ICH8/9 sata controllers work fine with SATA DVD Burners & NVIDIA sata controllers will work fine as long as you use the latest drivers. VIA chipset controllers won't work so you'll have to buy a SATA PCI CONTROLLER card w/the SILICON IMAGE 3112/3114 chipset for a SATA DVD Burners. Older motherboards w/SATA connections will have compatibility issues because they weren't equipped to be used for SATA DVD burners. Also check your motherboard BIOS to see if RAID is enabled, if it is then disable it.
    The dvd media you're using is considered crappy. Use VERBATIM or TAIYO YUDEN dvd media. Burn dvd media with IMGBURN because DVD DECRYPTER is no longer updated. Both of those programs were made by the same guy named, LightningUK. NERO BURN is buggy as hell and not reliable as IMGBURN when it comes to burning dvd media.
  6. Thanks again for the reply!
    My MOBO: Intel BOXDG965WHMKR LGA 775 Intel G965 Express ATX (http://www.newegg.com/Product/Produc...82E16813121052)
    Since the last time it stopped responding, I was able to burn about 5 DVDs with NERO, however when I play them back on my home dvd player, they all skip a little way into each movie...
    Then I tried to burn one at 8X... Less skips/glitches, but problems still there...
    Next, I tried a verbatim 16X DVD+R (lightscribe) disc at MAX speed, and it caused the burner to stop responding as it has done before, only this time it froze my entire system! I couldn't even get into the task manager!! Man, this just keeps getting worse!!!!
    2 things came to mind since my post... I thought maybe my home dvd player sucks so I put in a older dvd I burned with my NEC player about yr ago... It worked fine!
    The other thing I thougt is that maybe it's some type of system problem... maybe lack of HD space for swap files? I have 2 320GB drives that I store ISO files on to burn... One has 10.8GB free and the other has 15.8GB free...Seems like enough free space but maybe not? The reason I thought this b/c my NEC just recently started to burn discs with glitches in them - I just thought it was finally goin bad so that why I bought the samsung... But now the samsung is "kinda" doin the same thing (when it actually completes a burn), so I don't know what to think!!!!! ERRRRRRRRRR! I never imagined this much trouble!!!
    I'm starting to also wonder if the samsung just isn't all it's cracked up to be???
    I'll try imgburn and see what happens with that... Thanks again!
  7. DVD Ninja budz's Avatar
    Don't be burning VERBATIM or any other dvd media at the MAX SPEED. Just because you have a 20x speed dvd burner doesn't mean you'll be successful with the disc playing back correctly. The best you can burn is at 12x speed or if you use MEDIA CODE SPEED EDIT to swap write strategies with other media id. As I mentioned you're using crappy ass MEMOREX dvd media. Stick to the VERBATIM dvd media and you won't have any problems as long as you burn them at 12x. In my experience I've burned 16x speed with VERBATIM & TAIYO YUDEN with my SAMSUNG SATA S203B drives but I use MEDIA CODE SPEED EDIT to change the write strategies for certain media id's.
    Your motherboard should be fine but make sure RAID is disabled in your motherboard BIOS. This could also cause problems with dvd burning. Also make sure your SATA SAMSUNG Dvd burner is connected to the SATA port that has the INTEL ICH8 SATA controller. Your motherboard also has 3 additional SATA ports that are for RAID, which the dvd burner will not work correctly so if it's connected to it right now remove it and use the SATA connection that has ICH8.
    I don't believe your hard drives could be the reason for your problems. Make sure when you're burning dvd discs that antivirus and any other programs running in the background are disabled. Don't even surf the net as well. SAMSUNG SATA DVD Burners are the best in the market at this time.
    Hello, I came across this thread after searching for answers on the exact same problem. I too have the SH-S203N, which will freeze at various points during a burn. I've been using Verbatim DVD+R media along with DVDFab 3.2.1.0, DVDFab 4.0.3.2, DVD Decryptor, DVD Shrink 3.2, and Nero 6 & 7.... all with the same problem. At first I thought this was a hardware defect, but now I think it's something to do with the SATA connection. I just switched from using an IDE (Samsung as well) DVD-RW to this new SATA.
    Any advice on the problem would be great. The optical drive is connected to a Gigabyte P35-DS3P. I've tried the JMicron SATA port as well as the Gigabyte SATA on the board and come to the same problem with both. Currently AHCI is switched off, which I think could be the problem, but enabling it causes Windows to not load.
    Thanks again
  9. DVD Ninja budz's Avatar
    Don't use the JMicron SATA port. Connect the drive to the SATA port that uses the INTEL SATA chipset controller. I see your GIGABYTE GA-EP35-DS3P motherboard has RAID SATA controllers as well which could make a SATA dvd burner not work correctly. Also disable RAID in the mobo BIOS as well. I believe the SATA ports on the GIGABYTE mobo's are different colors. On one of my GIGABYTE P35 mobos the PURPLE port is for RAID connections and the ORANGE port is where my SAMSUNG S230B drives are connected to which means they're using the INTEL chipset controllers. Also leave ACHI disabled as well. If you don't understand about the ACHI read your GIGABYTE manual.
    Use IMGBURN to burn your dvd media. IMHO any other burning software is crappy. Good Luck!
  10. Member [_chef_]'s Avatar
    As nicely explained by budz, the sata controller is the biggest factor in this case.
    Its more frickin than you might think, because there are many controllers onboard sold these days which are just useless for SATA ODD. They only work well for SATA HDD, not to mention RAID..........
    If there is an option in the BIOS to set the controller to IDE or enhanced IDE, try that. RAID is a no-go with ODD.
    There is also the possibility for some sata controllers to flash them with a BASE BIOS which has RAID disabled, they should work.
  11. Thanks again for the suggestions!
    I have since been able to burn several DVDs with IMGBURN, but it seems that every 5 or so I have a burn that freezes half way, just as mentioned in my original problem... The completed burns actually play pretty well in one of my home DVD players, with only a few glitches... However, each one consistently skips near the beginning-middle of the movie in a different player I have at home... I'll admit this is the "pickier" of the 2 players, but then again it plays older DVDs I have burned just fine!
    OK, now getting to your suggestions...
    budz
    Well, I looked at my MOBO, the manual, and on Itel's site and I did find where they mentioned that ODD should plug into "Black" ICH8 SATA ports rather than "Orange" Raid ones, however all of mine appear to be black
    I have 1 HD in SATA0, and 1 HD in SATA1... Originally I had the new burner plugged into the SATA3 port, but then changed it to the SATA2 port. I haven't really noticed a difference since then...
    [_chef_]
    I have not tried this yet b/c I took a look and wasn't sure about something... In the bios it did have the SATA ports set to RAID. The only other options were "IDE", and "ACHI", but the last will only work for VISTA... I was concerned about switching this for 2 reasons... First, when I selected the IDE controller option, it cleared the list of SATA devices connected ( 2 HDs & 1 burner), as if nothing was there/connected??? 2nd, if I would select the IDE option, would it therefore slow the performance of my HDs, since they are both SATA 3Gb/s?
    Well, I really do appreciate all the help (and patience for my lack of knowledge)! I don't want to sound stubborn and I'm sure you gentlemen know a lot more about this than me but I just really hate to take a step "backward" in performance... If you know what I mean. See, I have been burning 4.7GB ISOs to Memorex DVDs with my 16X NEC burner, while surfing the net, printing labels for work, running AV, excel docs, etc, yet all those DVDs burned in about 6-7 mins with NO problems!
    Maybe I have just been really lucky in the past, but I'd really just like to get at least that kind of performance back. In other words, I'm trying to avoid buying all new DVDs (at least for now), burning slower, and waiting twice as long... Thanks guyZ
  12. Member oldandinthe way's Avatar
    This piece of your Nero log seems to show DMA is off on the burner.
    If you are burning without DMA it is quite easy to believe that when you reach higher transfer rates (outer areas of the DVD) the burn will crap out. Nero only uses a single core so you effectively have a slow system (2ghz), and no DMA. If any other program is using the same core the results will be even worse.
    Fix the DMA problem by uninstalling and reinstalling the drivers. It seems to me that the fact that your burner is SATA is probably a red herring. DMA off is a classic and common problem which is normally easy to diagnose.
    It also seems that your second Barrracuda is also running with DMA off. If you are burning from that drive your configuration is a disaster.
    After you remedy this - learn to read the Nero log, its worth the effort.
    In my experience Nero 7 issues a warning when DMA is off. Are you ignoring it?
  13. DVD Ninja budz's Avatar
    You are using MEMOREX dvd media which is considered crappy media. Use VERBATIM and TAIYO YUDEN and you'll see your problems disappear.
    The SATA connection for your drive should be set in the BIOS to ide. ACHI should be disabled in your BIOS. The speed of your HD's should not be affected. I'll have to read this thread over as I'm at work right now on lunch hour.
  14. Member oldandinthe way's Avatar
    Sorry Budz - this problem will exist with any media. The system is misconfigured,
  15. DVD Ninja budz's Avatar
    Then assist the OP in getting his sytem configured to how it is suppose to be!!!!! :P
    If you've got nothing constructive to contribute to this thread then refrain from making comments. I have 4 SATA DVD Burners which were all installed on different brands of motherboards with different chipset controller so I think I have a good idea on how to assist the OP.
  16. Wow! I should have noticed that!
    Nero did not show me any DMA warnings, and when the drive does work it's pretty fast so that's weird.... I have seen the DMA OFF warnings in the past when using DVDFab, and the speed difference was very noticable.
    I'm honestly not sure how to get them into DMA mode I've done it thru the device manager b4, but now when I go under the "IDE ATA/ATAPI Controllers" section, it doesn't even show SATAs.... It shows the primary IDE and the secondary IDE... 1 device is in ultra DMA mode, but the other 3 show "not applicable"
    I'd appreciate any guidence as to how to change this or uninstall/install the drivers! Should I just "update" the driver through windows or???? Can I even update the driver on the HD while it has items stored on it?
  17. DVD Ninja budz's Avatar
    I've already explained about your mobo sata controller chipset. Did you DISABLE RAID in the mobo BIOS? Move your hard drives to another SATA PORT and then move your SATA DVD Burner to SATA port 1 or 2. See if that works or not. Until you're able to exhaust all the options that is the only way to know for sure if your SAMSUNG SATA drive is defective.
    If you don't disable the RAID in the mobo bios then the drive will not work correctly. Also in the mobo BIOS make sure in the SATA ACHI mode you have it set to DISABLED & SATA PORT 0-3 Native mode set to DISABLED as well.
    Also in mobo BIOS make sure the ONBOARD SATA/IDE CTRL (controller) MODE is set to IDE. Hopefully you'll have these things listed in your mobo BIOS!
  18. Member [_chef_]'s Avatar
    Nero shows DMA off because "iastor" driver is used, which's settings Nero cannot recognize correctly. If the driver is named "atapi", Nero should report the DMA mode correctly.
    *** Now that you have read me, do some other things. ***
  19. OK, so I went in to the bios and changed from Raid to IDE... After it booted up, my computer caught on Fire!!!!!
    So after my girlfriend's cousin's dog put the fire out, I got it to boot up and it looks great! The controllers now make sense in the device manager, with DMA on! Thanks budz and everyone else for the help! Also, I learned the difference in the media as you mentioned. I grab a couple TDKs, which I had success with in the past, from a friend and they burned great and worked in numerous players... a little slower than the Memorex, but the Memorex had consistent glitches mid-way in some DVD players.
    I think I'm gonna grab some Verbatim from videohelp's sponsors... wouldn't make sense to buy'em anywhere else after such a good experience here. Thanks again guyz!!!
    Here's my Nero Log - (Hoping there's nothing wrong ) I have been using Imageburn and it's great... just used Nero this time to check the DMA in the log...
    oh and I may have exaggerated the fire part a lil...
    Windows XP 5.1
    IA32
    WinAspi: -
    NT-SPTI used
    (Nero Express)
    DiskPeripheral : ST3320620AS atapi Port 2 ID 0 DMA: On
    DiskPeripheral : ST3320620AS atapi Port 3 ID 0 DMA: On
    CdRomPeripheral : TSSTcorp CDDVDW SH-S203N atapi Port 4 ID 0 DMA: On
    AutoRun : 1
    Excluded drive IDs:
    BUFE : 0
    Free physical memory: 1440MB (1475044kB)
    Memory in use : 29 %
    Use Inquiry : 1
    17.1.2008
    Burn DVD Image
    11:04:50 PM #1 Text 0 File SCSIPTICommands.cpp, Line 424
    11:04:50 PM #2 Text 0 File Burncd.cpp, Line 3508
    11:04:50 PM #3 Text 0 File DlgWaitCD.cpp, Line 307
    Last address to be written: 2285849 (507:57.74, 4464MB)
    11:04:50 PM #4 Text 0 File DlgWaitCD.cpp, Line 319
    11:04:50 PM #5 Text 0 File DlgWaitCD.cpp, Line 2972
    11:04:50 PM #6 Text 0 File DlgWaitCD.cpp, Line 493
    11:04:50 PM #7 Text 0 File ThreadedTransferInterface.cpp, Line 793
    original disc pos #0 + 2285850 (2285850) = #2285850/507:58.0
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2285850 blocks [H: TSSTcorp CDDVDW SH-S203N]
    11:04:50 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 995
    DAO infos:
    MCN: ""
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681420800, ISRC ""
    DAO layout:
    0 | 1 | 1 | 0x41 | 2285850 | 2285850 | 0x00
    2285850 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
    11:04:50 PM #9 Text 0 File SCSIPTICommands.cpp, Line 215
    11:04:50 PM #10 Text 0 File Burncd.cpp, Line 4294
    11:04:50 PM #11 Phase 24 File dlgbrnst.cpp, Line 1762
    11:04:50 PM #12 Text 0 File Burncd.cpp, Line 4413
    11:04:50 PM #13 Phase 25 File dlgbrnst.cpp, Line 1762
    11:04:50 PM #14 Phase 36 File dlgbrnst.cpp, Line 1762
    11:04:50 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 2721
    11:04:50 PM #16 Text 0 File Cdrdrv.cpp, Line 9872
    Media type ID: R05
    11:04:50 PM #17 Text 0 File Cdrdrv.cpp, Line 9872
    Media type ID: R05
    11:04:50 PM #18 Text 0 File Cdrdrv.cpp, Line 9872
    Media type ID: R05
    11:04:50 PM #19 Text 0 File DVDR.cpp, Line 8376
    11:04:50 PM #20 CDR -1207 File DVDR.cpp, Line 6481
    11:04:50 PM #21 Text 0 File DVDPlusRW.cpp, Line 675
    11:04:50 PM #22 Text 0 File ThreadedTransfer.cpp, Line 269
    11:09:13 PM #23 Text 0 File WriterStatus.cpp, Line 113
    <H: TSSTcorp CDDVDW SH-S203N> start writing Lead-Out at LBA 2285850 (22E11Ah), length 0 blocks
    11:09:46 PM #24 Text 0 File DVDPlusRW.cpp, Line 935
    EndDAO: Last written address 2285856
    11:09:46 PM #25 Phase 37 File dlgbrnst.cpp, Line 1762
    Burn process completed successfully at 20x (27,700 KB/s)
    11:09:47 PM #26 Text 0 File SCSIPTICommands.cpp, Line 261
    11:09:51 PM #27 Text 0 File Cdrdrv.cpp, Line 11185
    11:09:51 PM #28 Text 0 File SCSIPTICommands.cpp, Line 424
    Existing drivers:
    Registry Keys:
  20. DVD Ninja budz's Avatar
    OK, so I went in to the bios and changed from Raid to IDE... After it booted up, my computer caught on Fire!!!!! So after my girlfriend's cousin's dog put the fire out, I got it to boot up and it looks great!
    so the dog took a piss on your pc to put the fire out!
    Glad to hear you got the drive working correctly. Happy dvd burning from now on with VERBATIM dvd media!
  21. Member [_chef_]'s Avatar
    As a note, I would only burn that specific media at 16x max.
  22. OK, I just don't get it.... I have since burned about a dozen perfect DVDs with the TDKs...
    Then, last night I tired to burn a TDK DVD and the burner again stop responding at about 68% while using Imageburn. Like before, I was able to close Imageburn but the burner kept spinning and wouldn't respond to anything or open until I rebooted... The only thing that was different this time was the color of actual DVD... Meaning, the first dozen or so TDKs given to me were plain white printables, while this recent burn used the same TDK DVD ( CMC MAG-M01), however the top is a gray color with writing on it.
    OK so I then rebooted and burned a DVD successfully, however it took about 8-9 minutes. Also, the Imageburn log showed 2 instances where the buffer had to recover, which I have Never seen before! I then burned another and it took even longer, and had 3 buffer errors/recoveries
    I'm waiting on Verbatims but I'm still not convinced this burner is not going to make coasters for them as well! I have a some Verbatim Lightscribes but I don't really want to waste thoughs either...
    Could the DVD color "really" make a difference, even though the media ID is identical?
    I'll post the log when I get home... If I don't throw my computer out the window 1st...
  23. Member [_chef_]'s Avatar
    TDK should be avoided these days, they have gone done the drain like Memorex..............
  24. OK, now I'm really pissed... My Verbatims arrived today, and guess what?
    Yup, 1st try and it stopped responding AGAIN!!!!!!!!!!!!!!!!!!!!!!!!! It actually made it all the way to 100% and showed "finished", but it just stuck there (sychronizing cache), and so I had to reboot....
    After reboot, I tried again. Well, it worked this time but barely made it over 4X????? WTF?
    Please, somebody, please????
  25. DVD Ninja budz's Avatar
    did you ever try removing the drive and connecting it to another SATA port? try doing that.
  26. Member
    i would swap out the drive with another. i have three of those drives in three different systems. they are all plugged in to different contrllers and all work flawlessly with verbatim. i consider the samsung one of my best drives.
    maybe you got a defect---it happens....
  27. OK, so I've been burning like crazy trying to figure this out... I moved the drive to another sata port, but unfortunately that made no difference.
    I have been able to burn a couple here and there but eventually it stops responding... One of the things I noticed was that when I opened IE while burning, the buffers where shot down and then it would crash or the speed never went back up above 4X on the samsung sata drive, however when I did the same thing while burning with the nec IDE drive, it barely noticed it...
    The only way I have been gettinig semi-consistant burns with the samsung sata is by limiting the speed to 16X, using Verbatims, and also being sure not to use any other programs during the burn...
    Is the IDE port somehow not affected by other tasks/programs that are running on the SATA hard drives, and therefore allowing that burner to run "unaffected"? I pretty much Always did other things while burning so I'm kinda spoiled... In other words, should I just buy another IDE burner so I can get away with more????
  28. DVD Ninja budz's Avatar
    First rule of thumb when burning dvd media is not to have any other programs running in the background. Dvd media will be costly if you continue surfing the net and have all other programs running while burning. If you want another IDE DVD burner then buy it. IMHO why waste money when you have a perfectly running SAMSUNG drive. :P
  29. Member [_chef_]'s Avatar
    Calm down and fix your SATA controller problems.
  30. Member
    does the Motherboard support ATAPI devices?????????
  1. Help Upgrading Firmware for Samsung SH-S203N
    By mn072065 in forum DVD & Blu-ray Writers
    Last Post: 8th Jul 2008, 06:50
  2. Questions about Samsung SH-203 SATA DVD burner
    By Phantom Of The Opera in forum DVD & Blu-ray Writers
    Last Post: 21st Nov 2007, 22:07
  3. Recode says 100% but burner stops responding
    By bgc99 in forum DVD Ripping
    Last Post: 18th Apr 2006, 04:47
  4. Burner stops responding
    By StoneColdWhat in forum Computer
    Last Post: 6th Mar 2006, 19:38
  5. DVD Maestro stops responding upon compiling
    By dhg6 in forum Authoring (VCD/SVCD)
    Last Post: 5th Nov 2002, 23:05
About   Advertise   Forum   RSS Feeds   Statistics   Tools
