I am having a problem with my system seeing this new TV tuner card and I am wondeing its it alright to use the other SLI slot which is x8 for this card that is part of the trouble shooting use a different slot and I am wondering if this one can be used on the M2NSLI Deluxe board.
Thread: HVR-1800
sandman
That card doesn't need a SLI slot at all. It may nor even work in a SLI slot. Tri a normal PCIe slot first.Originally Posted by cathudogRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
I have it in a PCIe x1 slot now and does not show up in the new hardware found in the device manager it is missing cannot be foound and the other slot I have is the other long slot I cannot get to my other x1 slot on the board so my question is will it work in the other slot the long PCIe one black in color which in the manual its say any x1 or x8 slot and that is what this slot runs at acording to the specs. I am a little under the weather and I may not be getting this across correctly can not spell either. Thanks
sandman
I've only got the HVR-1600 (PCI slot) so can't reply. Did you call Hauppauge support?
Do you like the 1600 because I am RMA ing this 1800 back to Newegg it is bad I tried it in another slot and it wouldn't let the system boot up so of it goes I think i am going to get the 1600 PCI version with the remote
sandman
Hauppaugr WinTV-HVR-1800 IR Remote trouble
By agoramilio in forum Media Center PC / MediaCentersReplies: 9Last Post: 21st Nov 2009, 08:36 -
WinTV HVR 1800/1850 - interlaced capturing?
By justin81 in forum CapturingReplies: 1Last Post: 10th Jul 2009, 10:13 -
Need advice on Capturing Software for WinTV HVR-1800
By Smack2k in forum CapturingReplies: 5Last Post: 6th Jul 2009, 14:46 -
Hauppauge WinTV HVR-1800 Jerky unless recording
By michaeldg1 in forum DVB / HDTVReplies: 4Last Post: 6th Apr 2009, 15:10 -
Hauppauge HVR-1800 Composite input - NO AUDIO
By jhg in forum CapturingReplies: 8Last Post: 1st Jul 2008, 16:20
