Hello, have anyone find a way to fix the IMG Burn "No device detected" trouble in linux. I was able to solve his problem with decrypter, but i really love the build feature of IMG Burn.
I'm running a PCLinuxOS 2007 on a AMD XP2000 with 1G of RAM, 2 DVD Burners and 2 HD.
By the way I'm a complete noob in linux.
Regards
Results 1 to 11 of 11
I want to believe....
Please elaborate. Its not clear as to what you are asking.
Run your wineconfig program. Might be in the menu if not, open a term, and type winecfg.
On the Applications tab, click add application, a browser should open, browse to ImgBurn.exe (Program Files\ImgBurn\ImgBurn.exe), change the type to Windows NT 4.0. Click apply.
Click on the drives tab, hit the show advanced button, make sure your DVD drive is listed as Type CD-ROM. If not change it. Click apply
Launch ImgBurn
Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
As far as I can tell, ImgBurn ONLY runs under Windows. That would mean that you are either running it under Wine or a similar emulator or running it in some kind of virtual machine. Running it in a virtual machine that runs some Windows variant should be OK. If you are using Wine, then for all we know your problem could be a Wine related issue. Wine emulation is not perfect and some programs don't run under it.
For Linux, there's mkisofs to create the ISO image from a Video DVD structure. Once you have the ISO, burning it to disk is equally (even more!) trivial - In Ubuntu, you just right click the ISO and select Burn to disk from the context menu. I'm sure there's some equally simple way in PCLinux. No need for anything else.
What I miss in Linux is more good apps to get the stuff off the original disk, than to create/burn my own...
Running XP in a VM works, but it's also a hazzle making the host machine hardware accessible to the VM.
/Mats
mkisofs in most default Linux systems has a 4gb bug do to being a hacked up bug ridden backport of 2004 code. Run mkisofs --version, make sure it doesn't point to genisoimage.Originally Posted by mats.hogberg
correct output -
mkisofs 2.01.01a33 (i686-pc-linux-gnu) Copyright (C) 1993-1997 Eric Youngdale (C) 1997-2007 Jorg Schilling
bad output -
genisoimage 1.1.6 (Linux)
Same thing with growisofs, which is used to burn DVDs in linux. You need to check that as well, with growisofs --versiion
bad output -
* growisofs by <appro@fy.chalmers.se>, version 7.0.1,
front-ending to genisoimage: genisoimage 1.1.6 (Linux)
good output -
front-ending to genisoimage: mkisofs 2.01.01a33 (i686-pc-linux-gnu) Copyright (C) 1993-1997 Eric Youngdale (C) 1997-2007 Jorg Schilling
This is because Jorg Schilling moved his licensing to CDDL, so distro mainters have implemented cdrkit, which includes wodim, and genisoimage, which are bugged versions of cdrecord (wodim) and mkisofs (genisoimage). It's also a well documented bug with K3B which has finally a work around IF cdrecord and mkisofs are installed.
A_51 clearly has wine installed as his posted noted to running DVDDecrypter.
PGC Edit, and DVDFab both run without issues using wine.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
I had the same issue with imgburn with wine. Do like disturbed1 says by going into wine's configuration screen then click on the drives tab.
Now click the autodetect button.
Your dvd/cd drive should now show up...but your not finished.
Click on the drive letter of your dvd/cd and then click the advanced settings.
Make sure that the drive is set to cd-rom and not hard drive.
When finished click apply and imgburn should detect your drive then!
Hope this helps.
I had a heck of a time with this myself.
Side note sometimes wine will forget your settings (at least on my system) and you may have to do these steps again.Donadagohvi (Cherokee for "Until we meet again")
My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
Thanks guys, it worked great...
just because i run on the same issue...
the quick fix is to copy on the \windows\system32 folder of WINE the wnaspi32.dll
and imgburn is able to detect drives
BHHHDConvertToX, AutoMen, AutoMKV Developer
I have the wrong versions in ubuntu 8.04 LTS x64 so I compiled the latest version of cdrtools but still when I check with mkisofs --version I still get the wrong version. So how can I replace it in ubuntu? I always seem to fail when I try to install something manually... No icons are created in the program menu, I don't know where the program is installed...Originally Posted by disturbed1
If you just did a simple make && make install, without specifying any preferences, it would most likely be installed in /opt/*whatever. You can do a find, whereis, slocate, or which command to locate the file.
cdrtools doesn't give you an icon
, they are cli only tools.
I can't believe the bug would still exist in current versions of cdrkit (Debian's cdrtools fork). Perhaps you should try it first before attempting to fix what isn't broke
Eac3to "Clipping Detected...2nd Pass" --> Avi2DVD finds no audio stream
By Murk in forum AudioReplies: 4Last Post: 5th Aug 2010, 16:27 -
Streaming RTMP, "SWF verification detected", JW player
By jasta in forum Video StreamingReplies: 0Last Post: 14th Dec 2009, 03:00 -
VRD-MC3 "Copy Protection Signal Detected: Cannot Record"
By cmwalsh in forum CapturingReplies: 6Last Post: 14th Jul 2007, 11:03 -
Avi2DVD message when loading AVI...."DV DVI Detected"
By geek2330 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jun 2007, 07:05 -
"Cannot append segment...", "Mismatch detected..."
By Ygramul in forum Newbie / General discussionsReplies: 2Last Post: 14th Jun 2007, 11:32
