Using badgers vob2mpg to extract from vob files file plays fine using bagers Mpegdetails and checks out ok in Avicodec as well to show codecs are supported. MPG File then imported into SVCD2DVD this plays fine in svcd window . Files are burnt to compliant DVD using imageburn from within SVCD2DVD .
However playing DVD in PC and on Pal Player, either picture stutters and then freezes, sound continues playing, or picture continues but sound plays for 1st 3 secs and then no sound. Extracting via dvd decrypter and burning disc the same vob files play fine. Any ideas[/b]![]()
Results 1 to 11 of 11
Thanks both logs are included in the one notepadfile enclosed
svcd2dvdlog-20080107082705.txt
Thanks for the logs....
ok when you use decrypter - are you still authoring with svcd2dvd?Extracting via dvd decrypter and burning disc the same vob files play fine. Any ideasSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
In answer to the quote using dvd decrypter , i am burning from within dvd decrypter and not authoring with the badger tools - this i believe shows that the vob extract from dvd decrypter is fine. I mentioned this just to help fault find .Originally Posted by ChrissyBoy
I notice the vob2mpg log files show buffer underflow , is this part of the problem?
So what are you creating the DVD-VIDEO with? Or are you not and just burning a data dvd with a vob/mpeg on it?
dvd decrypter allows via backup and re author option , this then scans the dvd and burns to DVD . dvd decrypter doesnt have any fancy DVD menu options . the options are re author or backup full disc , its re encoded if larger than the destination to fit size ie 4.7 blank dvd. It creates the appropriate DVD compliant dvd folder structure and burns to hard disk or DVD. Re encoding if neccessary only for DVD burning, For hard disk folder no encoding takes place. However this doesnt allow a dvd menu to be created , Im illustrating the point that i dont believe dvd decrypter to be at fault as a dvd created on the above works fine.
If i want a DVD menu which I do, Once the vobs are extracted as in the above via dvd decrypter its option of saving the vobs to a hard disk folder is used, Dvd decrypters job is finished at that stage
Onto vob2mpg to create a mpg from these vobs in the hard disk folder
Import the mpg created into SVCD2DVD
Sort out using the menu option and create Menu and Burn to dvd from within SVCD2DVD
Once the DVD is created from within SVCD2DVD then I have a problem with playback as described in the original post
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
This is why I asked. Decrypter does NOT re-encode.It creates the appropriate DVD compliant dvd folder structure and burns to hard disk or DVD. Re encoding if neccessary only for DVD burning, For hard disk folder no encoding takes place.
This is a description of DVDShrink and fits a few other tools as well, DVD Decrypter is not one of them (but DVDFab Decrypter is).dvd decrypter allows via backup and re author option , this then scans the dvd and burns to DVD . dvd decrypter doesnt have any fancy DVD menu options . the options are re author or backup full disc , its re encoded if larger than the destination to fit size ie 4.7 blank dvd.Dwight
- Herm Albright
Also, which version of decrypter are you using?
Dwight
- Herm Albright
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum CapturingReplies: 2Last Post: 22nd Dec 2011, 10:50 -
Unable To Register BOTH SVCD2DVD & VOB2MPG Pro
By noyou in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 1st May 2010, 21:23 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
Interesting copy results (vid extraction) ...
By cwb in forum LinuxReplies: 0Last Post: 13th Jul 2009, 10:07 -
Vid encodes will only display first frame instead of loop at the end of vid
By SignedupGuest in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2008, 22:09
