Howdy Folks:
A bit off topic - figured I'd ask
purchased a router to go with Cable modem to run 2 machines at once both Linksys
both Mac's
since hooking up the main machine used to download/upload has communication errors and dodgey upload rates
mainly using Azurues
any ideas?
CHEERS in advance
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Howdy TerryJ :
TerryJ to the rescue again : Cheers thanks for the reply :
Ok I think I managed the port forward with Azureus - yet Transmission Uploads are pitiful - remembering you do not know about Transmission - the Site is down for maintenance right now
Question - If I have 2 computers running - both Azureus - would I have set upload and download rates even with a router - I have Cable internet with 5Kbps - average is 700bps
Right now if I run just one machine thru the cable modem - I can upload up to 85-90Kbs - 2 machines running I average 65-70 between the 2 - same as if I were running Azureus and Transmission together on same machine
does this make sense?
Cheers in advance:
you can test your up and down speeds here -
http://www.speakeasy.net/speedtest/
cable modems share the connect between computers so with 2 you would divide the max in half when both are using it.
one thing you might try is unplugging your modem from the power for 5 minutes and then letting it reboot. comcast and others send out firmware updates without notifying users. the updates can allow higher speeds.--
Howdy Aedipuss:
Cheers ya for the speed test
Best down 5289 Kbps best up 545 Kbps
this would suggest I could run 2 machines - One Transmission and one Azureus simultaneously around 60-70kbps each - no?
just have to figure out the router sitch - just bought a newer router as the Linksys BEFSR41 v2 is older - cant see a UPnP option on its page - bought same model v4
Cheers:
you shouldn't have any problem with those speeds.
Audio slightly out of sync after Youtube upload. Any hints?
By gmania in forum AudioReplies: 2Last Post: 24th Oct 2009, 14:32 -
Using avisynth on two machines
By CogoSWSDS in forum EditingReplies: 1Last Post: 26th Dec 2008, 22:40 -
what does this mean?(quote from another topic to upload hq vids)
By bojadada in forum Video StreamingReplies: 1Last Post: 24th Oct 2008, 03:24 -
Building A Video-Editing PC (slightly off topic)
By GrayStrickland in forum Media Center PC / MediaCentersReplies: 4Last Post: 26th Feb 2008, 13:39 -
Can a router/wireless router shut down computer?
By tmh in forum ComputerReplies: 7Last Post: 29th Jan 2008, 12:34
