    I have a Philips DVDR3475/37 standalone and every DVD I burn has this annoying Menu Screen that pops up with two scenes. One is my video the other is blank and cant be deleted before or after finalizing. I have searched the manual for a setting that would turn this off but cant find it. All I want is for the DVD to just play when inserted in a dvd player.Any thoughts?
    Daryl
    I have a Philips DVDR3575, and assuming it works the same way, you can use DVD+R discs in the 3575, and the 3575 and other DVDRs (at least my Panny player) will not auto-display the menu screen. They will load, show a "+R" briefly on screen (in the 3575, nothing on my Panny), then sit there waiting for your command to show Disc Menu or PLAY. If you load the +R disc then press PLAY (not Close the tray), the disc will auto-play from the beginning.
    A DVD-R created in the 3575 will always auto-display the title menu in the 3575 and prob. most other DVDRs.
    Commercial DVDs will do whatever the producer wants it to do. Mine play at least the FBI warnings, etc., then either play or put up a menu for op. selection.
    To get rid of the Empty Title block, you have to rec. something of the length it shows (fill up the disc), then delete that title before finalizing.
    This happens strangely with the Magnavox I picked up recently from Walmart. The best thing I say you can do is fill up the blank (overwrite it) and when it fills up the disc space go edit it and just delete it. I know it's not the same brand or dvd recorder but that's what I have been doing with the similar problem.
  1. Need some Feedback: Philips DVDR3475/37 and Samsung DVD-R135
    By BrokenOne in forum DVD & Blu-ray Recorders
    Last Post: 17th Dec 2007, 00:58
  2. Replies: 8
    Last Post: 19th Jul 2006, 22:56
  3. scene selection menu plays only sound of the clip
    By sirtet in forum Authoring (DVD)
    Last Post: 18th Jan 2004, 12:48
  4. screen grabs for scene selection menus - what tool / method?
    By housepig in forum Newbie / General discussions
    Last Post: 3rd Jun 2003, 01:00
  5. How do I make an advanced scene selection menu?
    By RoachCoach7 in forum Authoring (VCD/SVCD)
    Last Post: 16th Jul 2002, 05:18
About   Advertise   Forum   RSS Feeds   Statistics   Tools
