I'm helping someone get DVDfab working and we're trying to convert a DVD for play on a Zen Vision:M but after DVDFab rips and converts the file and we transfer to the Zen, I get video, but it says "Audio format not supported." On top of the the Creative Video Converter won't work on the file created by fab (it's an XviD file). Any help would be greatly appreciated.
(preferrably with the fewest steps)
TIA
Thread: DVDFab and Zen Vision:M
Nothing can stop me now, 'cause I don't care anymore.
As a former Vision:M user, It should take Xvid files without a hitch. Check what the audio settings are in DVDFab.
BTW, if you use the standard DivX encoder that comes with the codec, you can change the .divx file extension to .avi and the Vision:M should take it.
Also, you should definitely stay away from Creative's tool to convert files. I used AutoGK and simply set it up for a 1-CD encode with a 320x240 size. I don't think I had a single problem with needing to reencode before syncing.
Creative Zen Vision:M connectivity problem?
By sailor_girl in forum AudioReplies: 2Last Post: 23rd Feb 2009, 18:34 -
Zen Vision W owners, what are you using?
By linetest in forum Portable VideoReplies: 13Last Post: 31st Oct 2007, 12:15 -
How to put DVDs on Zen Vision: W
By cali_n_alley in forum Portable VideoReplies: 2Last Post: 28th Oct 2007, 19:14 -
What is the best video converter for my Zen Vision: M?
By arreat89 in forum Video ConversionReplies: 1Last Post: 31st Jul 2007, 22:03 -
CREATIVE ZEN VISION M (30gb) Connection problem
By wrestleuk in forum AudioReplies: 1Last Post: 17th Jul 2007, 19:41
Statistics
Newest guides
Latest tool updates
New media comments
