hi guys ,,,
first of all im sorry if this is repeated question ,,
i was reading all over the net till i found this place
i have dishnetwork and im getting sick of it and im switching to directTV my question is
is it possible to record from Direct tv to my pc through Tv tuner ,, i dont want HD cose i dont have any
and if yes what is the best cheap Tv tuner i can get ?
and how to set it up .. i was thinking since i can get up to 4 recivers to ask them to give me one reciver just for the computer and then from there hook it up to my Tv tuner ,,
im not sure about all that ,, im just assuming and through my reading alot of ppl said you cant record from direct TV cose they encrypt of have special signal
i would really appreciat any help
thanx in advance
Thread: direct Tv question and tv tuner
This is correct: "you cannot record from DirecTV because they encrypt the signal". Best you can do is an analog capture, and any good capture card or DVD recorder will do.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
thanx lordsmurf for replyin ,, but again would you please explain to me what is analog capture ?? and how i can do it ..one more thing please would you advice me for DVD recorder that support Dvix in reasonable price
thanx
I have direct tv and i use to capture off the receiver or direct tv tivo. using my capture card before i got a dvd recorder.
Direct TV/HDTV Signal Question
By RKelly in forum DVB / HDTVReplies: 5Last Post: 12th Mar 2010, 00:55 -
Question about difference between direct capture and sound card recording
By jimdagys in forum AudioReplies: 3Last Post: 16th Sep 2009, 09:09 -
Direct Cable Or Digital Converter Box, quality question
By allthumbs in forum CapturingReplies: 20Last Post: 3rd May 2009, 20:55 -
I have a question how to get hd quality on a tuner
By sdavis in forum CapturingReplies: 5Last Post: 16th Dec 2008, 15:52
Statistics
Newest guides
Latest tool updates
New media comments
