Im trying to burn my Heroes AVI files on to DVD-RW so that I can watch on my Samsung HT-Q20 Divx DVD player linked to my 32" tv.
I would ideally like the video to fit to the screen as when watched on the PC it is a bit small.
Here is the details of the file :
Video
Frame Width : 624
Frame Height: 352
Data Rate : 107kbps
Total Bitrate : 235kbps
Frame rate : 23fps
Audio
Bit rate : 128kbps
Basically I need a program to convert (not sure if I even need to convert), resize and burn to DVD-RW. I have manged to do this once but was unsuccessful to get any sound. Im using Phillips DVD-RW 4.7GB 1-2x speed (I think these are too slow) and Verbatim DVD-RW 4.7GB 4x speed (which i think are ok)
What are the best program to use?
Let me know if you need any more details.
Thank you for your help in advance.
In what way doesn't it play back to your liking on your TV? 624x352 is darn close to 16:9 (which I suppose your TV is too) and as your player plays divx, you'd just burn the AVI as is as data to a CD-R or DVD-R and it sjould play back full screen.
/Mats
Thanks for reply.
The main problem is sound, when i did get it to work there was no sound.
If I burn as data, will the sound work and what program should i use? Nero?
Ive seen some posts about interleaving the sound? Not sure what to do.
Burn as data using anything. Even Nero can't botch that.
If your source file is AVI, it's DivX or XviD video, MP3 or AC3 audio and not stuff like GMC and QPEL, you should be fine. Just burn it to a disk and try! Not harder than that.
/Mats
Mats, your a legend!!!
If only i knew it was that easy!!
Thanks for all you help.
Jay
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 6Last Post: 20th Mar 2012, 10:22 -
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 24Last Post: 31st Jan 2012, 07:07 -
burning divx files as data to play on dvd player
By penguyen in forum Authoring (DVD)Replies: 4Last Post: 30th Jul 2011, 10:54 -
Burning HDV AVI to DL-DVD to play on BR player.
By suppafreak in forum Authoring (Blu-ray)Replies: 5Last Post: 6th Oct 2009, 19:25 -
burning an xvid video file to play on dvd player
By Meggie in forum MediaReplies: 8Last Post: 9th Sep 2009, 07:26
