Anyone ever come across those boxes that hold 3-4 DVDs (usually slim)? You can find them in multi disc sets (Futurama, Family Guy, etc.)
These are simple cardboard. I've looked, and the closest I've found is plastic, slotted cases that hold ten regular DVDs.
I'm looking to put together my own set for some TV season and other like discs that don't have their own set boxes.
Thread: Where to get DVD box set boxes?
I want to find the ones that were used for Gomer Pyle S2 and S3. Those hold 6 discs in a single-sized case. And it's pretty nice, too.
What I'd really like is blue (Smurfy blue!) multi-disc cases. I have some doubles I bought about 3 years ago, but that's all I've ever seen.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
You need something like these:
http://svp.co.uk/product/amps_4_way_...rage_case_0094
http://svp.co.uk/product/amps_6_way_...case_0103_x100
http://svp.co.uk/product/amps_10_way..._case_0064_x44
and others.
All made by AMPS so you may be able to find them available in the US somewhere. Do not appear to be available in blue though......
ls, you can find the 6/1 at most PC stores (Fry's, Microcenter, etc.) I just got a pack of those and the 4/1 for 7.99 and 5.99, respectively.
The overlapping of discs on the AMPS site (see above links) worries me. Anyone see others that are a single disc per 'page' of the holder?
Like these: http://www.shop4tech.com/item2541.html
I have some that hold 4, 6, 8, and 10 discs (each insert holds 2, one per side).
I've seen them other places, but I'm not at home and don't have my links or receipts handy. I didn't order them from shop4tech and I DON'T recommend them.
EDIT: More here: http://meritline.com/multi-dvd-case-cases.htmlGoogle is your Friend
Searching for DVD Box set
By Arok01 in forum ComputerReplies: 5Last Post: 20th Mar 2011, 11:26 -
Possible to author a 23GB DVD onto a BD-R and play it on a set top box?
By litmus in forum Authoring (Blu-ray)Replies: 2Last Post: 21st Feb 2010, 15:42 -
setting up dvd / tv / set top box??
By wundahoss in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th May 2009, 12:48 -
high deffinition set top boxes australia
By phillbrett68 in forum DVB / HDTVReplies: 1Last Post: 13th Dec 2008, 05:37 -
Difference Between Expensive & Cheap Set Top Boxes?
By markannab in forum DVB / HDTVReplies: 8Last Post: 3rd Jul 2007, 01:18
