Hi,
Just wanted some help playing a PAL disc. I have a Toshiba upconverting DVD player (D-R400) hooked up to a Samsung LCD TV (LNT5265F). When I play a PAL disc the video appears jerky, when I play a NTSC disc, however, the video is smooth. I know the dvd player supports NTSC and PAL but I'm not sure about the TV. Is there anyway to fix the jerky video with PAL discs? Maybe there is a setting I could change?
Thanks for the help.
Anyone? Or if you can point me to a site where there might be some info?
Describe "jerky". Is it completely unwatchable?
The player may very well "support" PAL....in a PAL country(meaning it is outputting a PAL signal)....you need it to output an NTSC signal via the player converting PAL to NTSC on the fly.
You need to do some research to find out if this player indeed does convert between the two formats. You can also check in the players menu for an "output" setting/option.
Hey hech54,Originally Posted by hech54
The video is watchable but is slightly jerky as the picture freezes for a few ms every second. It gets annoying after a while.
Sounds like the typical result of a player that can't perform PAL to NTSC very well. The only solution, is to get a player with good PAL to NTSC conversion.
Google is your Friend
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 5th Nov 2009, 08:59 -
Toshiba D-R400 Pass-thru
By wulf109 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Apr 2008, 00:44 -
Toshiba D-R400 QUestion on Playing Back AVIs
By shaggy2002 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 25th Nov 2007, 14:09 -
Toshoba d-r400, anyone have this?...
By rubberman in forum DVD & Blu-ray RecordersReplies: 2Last Post: 23rd Oct 2007, 17:35 -
Toshiba D-R400 DVD Recorder - Is it PAL enabled?
By JEG in forum DVD & Blu-ray RecordersReplies: 2Last Post: 25th Aug 2007, 16:27
