I've got an mpeg2 video with ac3 audio created with vob2mpeg. The mpeg plays perfectly in sync. However when converting to divx with VirtualDubMod it adds an audio skew at the start of the resultant avi.
Does anyone know how to:
- Avoid the audio skew in the first place
or
- Change a setting in VDM to offset the audio to have aud/vid sync (the auto option doesn't work...)
or
- Demux, add skew to audio, remux
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
Streams->Stream List->Right-click the audio->Interleaving->Delay audio track by xxx ms.Change a setting in VDM to offset the audio to have aud/vid sync (the auto option doesn't work...)
DelayCut can do that.Demux, add skew to audio, remux
How do you know that? How do you know there wasn't already a delay in the MPEG that wasn't taken into account when you converted to DivX? If you are incorrect in your assumption that the conversion to DivX was responsible, then:However when converting to divx with VirtualDubMod it adds an audio skew at the start of the resultant avi.
Find out the initial delay. One way is to open the MPEG in DGIndex and Save Project File. The resulting AC3 audio will have the delay as part of its name. Add that same delay to the DivX audio, or use DelayCut to get rid of it entirely.Avoid the audio skew in the first place -
Have a good one,
neomaine
How to add permanent subtitle to a video with virtualdubmod
By Baldrick in forum SubtitleReplies: 258Last Post: 28th Dec 2015, 15:57 -
virtualdubmod no audio problem
By hell in forum Video ConversionReplies: 0Last Post: 4th Jan 2010, 16:49 -
Audio skew correction causing static in begining of audio.
By NextJinGamer in forum AudioReplies: 1Last Post: 3rd Sep 2008, 14:33 -
VirtualDubMod - Does it keep audio sync?
By vodmare in forum Video ConversionReplies: 4Last Post: 13th May 2008, 01:15 -
Problem with SKEW audio
By themaster1 in forum EditingReplies: 0Last Post: 22nd Jun 2007, 21:35
