    hi,
    I want to convert a dv-pal file (made with final cut) in an avi divx by using preset divxffmpeg.
    The result is a file without audio track.
    This is the log in the end of the process:
    Input #0, yuv4mpegpipe, from 'pipe:':
    Duration: N/A, bitrate: N/A
    Stream #0.0, 25.00 fps(r): Video: rawvideo, yuv420p, 640x352
    Output #0, avi, to '/Volumes/LaCie/Capture Scratch/emecnet meet eu - dic.07/segmento prova.mov.ff.avi.e.avi':
    Stream #0.0, 25.00 fps(c): Video: mpeg4, yuv420p, 640x352, q=2-9, 1265 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    bench: utime=1.120s
    video:565kB audio:0kB global headers:0kB muxing overhead 1.146726%
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Mac OSX universal build for ffmpegX
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/LaCie/Capture Scratch/emecnet meet eu - dic.07/segmento prova.mov':
    Duration: 00:00:03.2, start: 0.000000, bitrate: 30220 kb/s
    Stream #0.0(eng): Audio: pcm_s16be, 44100 Hz, stereo, 1411 kb/s
    Stream #0.1(eng), 25.00 fps(r): Video: dvvideo, yuv420p, 720x576
    Codec type mismatch for mapping #0.1 -> #0.0
    If I play the source file with quicktime I have audio.
    Can someone help me?
  2. Explorer Case's Avatar
    DV should be 48000 Hz, but I don't think that influences this conversion.
    Input from 'segmento prova.mov':
    The audio stream is listed before the video stream. ffmpegX wants that reversed.
    I checked if that can be adjusted by using the "Invert mapping" checkbox, but it seems to have no effect for my test DV source.
    All DV here are video before audio. I have no idea why Final Cut would export a DV file with reversed streams.
  3. Explorer Case's Avatar
    You can reverse the stream order manually with QuickTime Pro.
    Open the dv.mov in QuickTime Player. Export Sound to AIFF. Show Movie Properties on the dv.mov. Delete the Sound Track. Open the AIFF file, select all, copy to clipboard. Switch to dv.mov file. Select all. Add to Movie. Show Movie Properties, check: video is listed before audio. Save as self-contained movie.
    ffmpegX should now convert both video and audio.
  1. Replies: 13
    Last Post: 12th Oct 2007, 09:40
  2. Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
    By jdfrosty in forum ffmpegX general discussion
    Last Post: 17th Jul 2007, 19:31
  3. audio out of sync in converted file, but good in original avi file
    By ibzomie in forum Newbie / General discussions
    Last Post: 17th Aug 2006, 11:23
  4. Replies: 0
    Last Post: 16th Apr 2003, 13:45
  5. MP2 audio file conversion to wav audio file-How?URGENT
    By alfa1234 in forum Video Conversion
    Last Post: 10th May 2002, 15:21
About   Advertise   Forum   RSS Feeds   Statistics   Tools
