VideoHelp.com Forum
    I have a bunch of files that are h264/AAC in an mkv container. I want to convert them to mp4 so I can play them on my iphone. They are already the appropriate size and codecs, so I really shouldn't have to transcode them at all!
    I can use iMKVExtract to demux the mkv, but the mux in ffmpegX won't write to MP4.
    I tried using VLC, but that resulted in no video, just audio. I checked the "dump raw data" option, then I got both, but it would only play in VLC, not quicktime or itunes.
    What else can I use to put these properly encoded streams into a new container for iTunes to read? Please keep in mind I'm on OS X.
    Thanks!
  2. joshwa
    Member
    New post Posted: Jan 03, 2008 20:09 Posts Comp View users profile Send private message Reply with quote
    joshwa there's a program on here called gotsent it turns mkv to mp4 i use it to turn to mp4 for my ps3.
    Try AviDemux.
    gotsent -> windows only
    avidemux -> crashes on my machine (tried both qt and gtk builds)
    Try MPEG Streamclip http://www.squared5.com
    Open the MKV and then from the File menu choose Save As, then MP4. If you get an error try saving instead as MOV
    The only other way that I've had limited success with is the mp4creator CLI utility in MPEG4IP http://mpeg4ip.sourceforge.net/
    However in my experience mp4creator chokes on h264 video, YMMV.
    thanks, fugu:
    MPEG Streamclip -> can't open mkv-- unsupported file type. Force didn't find the tracks.
    mp4creator -> No OS X binaries available.
  7. Member Krispy Kritter's Avatar
    The problem, as you are finding out, is most software is written for the PC. Add to that, the fact the 99% of the members here only have experience using the PC software. You will likely need to find a dedicated Mac forum.
    On a side note, even in the PC world, software support for mkv files is spotty. Have you tried QuickTime Pro?
    Google is your Friend
  8. VH Wanderer Ai Haibara's Avatar
    Umm... Krispy? VideoHelp does have a dedicated Mac forum, more or less. Perhaps this post should be moved there?
  1. how can i mux to mp4 from h264/aac using ffmpeg
    By DKhanh in forum Video Conversion
    Last Post: 18th Nov 2011, 20:08
  2. mux h264/aac flv into h264/aac mkv
    By Pitorasilo in forum Newbie / General discussions
    Last Post: 18th Jul 2011, 09:36
  3. MKV [h264/aac] to mp4 conversion problems...
    By DestructoEH in forum Video Conversion
    Last Post: 12th May 2009, 19:19
  4. H264/AC3 (MKV) to H264/AAC (MP4) ?
    By jccca in forum Video Conversion
    Last Post: 13th Dec 2008, 19:06
  5. remux h264 and aac to mp4
    By madmillington in forum Video Conversion
    Last Post: 6th Feb 2008, 14:18
