VideoHelp.com Forum
    It seems like I have a problem I have gone through 10 Taiyo Yuden DVD-Rz and still no luck...
    What happens is I am trying to convert this PAL to NTSC via FAVSC and everything works out smoothly until it opens IMG Burn to Burn the files...
    IMG Burn opens I say Burn and then it goes Writing LeadIn and then it it says 5% then it says Syncronizating and it completes...No Files on DVD-R
    Please help me I have pix shoing my FAVSC Setup and GSPOT Video I am trying to convert...Please help me fix this Problem...thanks
    [/img]
    Sorry if this is the Wrong Thread It might be a DVD Authoring Question so if it is Could someone move it to DVD Authoring please. thanks
  3. Member Bulldog57's Avatar
    hi sandman423 IMG Burn could be the prob
    make iso and burn with nero hope that works.
    PS. up date fav theres a new fav 105 out in tools .
    Bulldog57
  4. Member FulciLives's Avatar
    I don't use FAVC but looking at your screen shots I see a big NO NO. You have it set to NOT make an ISO but then to burn with ImgBurn.
    While it is true that ImgBurn can burn from a set of DVD Video files it is advised to make an ISO first. I bet you that is the problem.
    Also as an aside ... I see you are using QuEnc as your encoder. HC is a much better encode and is just as free.
    - John "FulciLives" Coleman
  5. VH Wanderer Ai Haibara's Avatar
    Actually, I'd recommend trying to burn the ISO with Imgburn, over Nero.
    As for FAVC 1.05, some people have apparently been having problems with it, according to this topic:
    http://forum.videohelp.com/topic342822.html
    It may be better to stick with 1.04, for the moment.
  6. Always Watching guns1inger's Avatar
    NEVER burn directly after converting. That way lies madness and a big pile of coasters. No program is reliable enough to trust without testing the output first.
    Always convert to a HDD folder, then test the output, then burn.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Cool ISO Was a good Idea...it looks like it might be working thanks
  1. Replies: 32
    Last Post: 20th Jan 2011, 21:16
  2. PAL to NTSC conversions advice please !
    By beammeup in forum Video Conversion
    Last Post: 21st Mar 2009, 22:11
  3. FAVC Pal-Ntsc conversion question
    By spiritgumm in forum Video Conversion
    Last Post: 24th Feb 2009, 10:12
  4. changing sup to srt for FAVC (Pal to Ntsc)
    By spiritgumm in forum Subtitle
    Last Post: 13th Jan 2009, 11:57
  5. Replies: 35
    Last Post: 20th May 2007, 21:48
