Hello, I have video, which is split into parts with file extensions .z01, .z02, z03, etc., what program would I use to join/unpack this?
Thank you.
Probably WinRaR. You could also try the freeware 7-Zip. Usually .rar files end in XX.r00, XX.r01, etc. The 'Z' might refer to 7-Zip, though. WinRaR is a bit easier to use with multiple files. The programs should rejoin them all into a single file.
WinRar: http://www.rarlab.com/
7-Zip: http://www.7-zip.org/ -
Tried - winrar, 7-zip, windows own zip utility, hj split, nothing works, googled, other are having the same problem, with no luck.
Then you may have a fake or corrupted file. Not uncommon off the net.
There should be instructions on how to use the files from where you legitimately got them.
For example, I sometimes buy files from Rifftrax.com. They are in .zip format, so the site instructs downloaders to use winzip or any other program that can handle zip diles.
Check if the site has a faq (frequently asked questions). -
Solved, there was one file with .zip extension, which I unpacked with winrar, thanks.
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 16:21 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
.iso unpack
By christopheramos in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2007, 08:10 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
