hello,
i have a Blackmagic Design intensity (not intensity pro). I use adobe premier pro CS 3 on Pc with windwos XP (SP2). I want to capture Xbox 360 video game footage from the HDMI port. I connect my TV HD from BM card.
I have the 1.8.2 software version of BM card
Here is how it's conect
Xbox 360 -> PC (BM card)
PC (BM card)-> HD TV
From media express (software from card) i don't see anything on computer but on HD TV i see video come from Xbox 360. So video record is blank on my PC.
From Premiere pro same problem.
Xbox 360 is setup on 720p 50hz and on premiere pro i use the same setup.
I try with virtualdub but it's the same problem
So what can i do ? Help will be nice
note :I try to do from PS3 and then nothing on TV and on PC![]()
Results 1 to 12 of 12
I thought the intensity pro doesn't decrypt the digital signal?
i have this one : http://www.4videoequipment.com/video...x1+Lane+MAC/PC
Not this one : http://www.4videoequipment.com/video...MI+I/O+Capture
with intensity i can't use component because don't have it.
Yea exactly... I ways always under the impression intensity can only record from a non-encrypted source like a Camera
The BlackMagic Intensity dumps uncompressed video to the PCIe bus. The data rate exceeds what any single drive can handle. You need a RAID for uncompressed capture. They also supply software for MJPEG compression that can work realtime with fast CPUs. This would use the supplied BlackMagic codec driver.
http://www.kiva.org/about
Wich kind of "supply software for MJPEG compression " do you mean (name) ?
The MJPeg codec is supplied by Black Magic with the card.Originally Posted by jonakangouRecommends: Kiva.org - Loans that change lives.
I hate to bump this topic, but I'm having the exact same problem. I'm not getting any preview in media express. I've set the correct input/output as well. The hdmi in isn't encrypted via HDCP. I was wondering if anyone could help me.
I don't have the card but you can monitor off the second HDMI port. Are you encoding to MJPEG or capturing uncompressed? Avid Media Express may or may not handle the BlackMagic MJPEG codec. Call either company for support.Originally Posted by kelceyRecommends: Kiva.org - Loans that change lives.
I'm doing uncompressed. I'm using the blackmagic media express. This is so annoying.
I had the same issues of blank video but managed to find a fix on another site! The manual doesn't mention it but you have to go to the windows control panel because the driver install put an "Intensity" control panel item there that requires you to select the inputs and outputs.
Actually, my problem was a bad converter from HDMI->component (I refuse to use the intensity pro's component inputs). I switched my converter and now it works with 720p
Blackmagic Intensity Pro - Xbox 360 to PC capture audio issues
By xmadmardiganx in forum CapturingReplies: 71Last Post: 22nd May 2011, 17:28 -
blackmagic intensity pro xbox 360 help
By tehshame in forum CapturingReplies: 11Last Post: 18th Nov 2010, 14:24 -
Help capturing from Xbox 360 with Blackmagic Intensity Pro
By SkinnyRabbit in forum CapturingReplies: 10Last Post: 1st Oct 2010, 09:44 -
Blackmagic Intensity Pro + Xbox 360 Hookup Question
By xmadmardiganx in forum CapturingReplies: 6Last Post: 15th May 2009, 16:52 -
Best HDMI Splitter for Use with Blackmagic Intensity Pro + Xbox 360?
By xmadmardiganx in forum CapturingReplies: 0Last Post: 22nd Apr 2009, 14:27
