VideoHelp.com Forum
Thread: 480p problem
  1. when l use progressive scan(480p only) to watch dvd, there is black line showing up on screen once in a while, very annoying, l want to ask what causes this problems? is it the component cable? or the tv? when l change it back to i scan or use the normal av cable, the problem seems gone or greatly reduced, l dont think it is the dvd player though, since my two dvd players display the same problem..
  2. Member edDV's Avatar
    Experimemnt to see if the problem goes away by substituting
    1. A different DVD disc
    2. A different DVD player
    3. A different component cable
    4. A diffferent progressive TV
    http://www.kiva.org/about
  3. Member Krispy Kritter's Avatar
    Aside from trying a different DVD, if you are having the same issue with two different DVD players, then the issue is likely your TV. You will have to live with 480i or get a new TV.
    Google is your Friend
  4. I had a cheap Sanyo HDTV that I couldn't use progressive on without the picture screwing up. The Panasonic plasma I have now it doesn't make a bit of difference if I use 480i or 480p, the picture looks the same either way. Your TV probably upconverts either signal anyway, so unless you see a big difference on progressive, I wouldn't worry about it.
  1. 480p to 720p
    By Ally68 in forum Newbie / General discussions
    Last Post: 9th Dec 2010, 17:09
  2. Help Resizing 720p » 480p
    By Enkidu in forum Newbie / General discussions
    Last Post: 27th Jul 2010, 13:17
  3. How can I check to see if a DVD is 480p or 480i?
    By Joe The Dude in forum DVD Ripping
    Last Post: 9th Feb 2008, 07:30
  4. Problem with 480p capture. Video seems squished...
    By Mysteriouskk in forum Capturing
    Last Post: 9th Feb 2008, 01:24
  5. 480i/480p in DVcam vs. conversion
    By celticwhisper in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 19th Jun 2007, 11:54
