Hello,
I have a selection of Japanese Anime & movies (Xvid, DivX & Mpeg2 encoding) primarily saved as *.avi file extension. I use Media Player Classic & Regular WinXp Media Player 11 to watch them.
I have the following 3 queries:
1. I would like to translate them my self and create my own subtitles from scratch in English as well as in Greek. I noticed that the soft subtitle file types supported by DirectVobSub, are *.srt & *.sub. Both have a different timing structure. What is the best tool to create my own software subs and the right timing so that the subs will be in sync with the voice speech of the Anime?
2. What is the best subs file type to save as, *.srt or *.sub? Or are they equal?
*.sub look like this:
{600}{850} text
{1932}{2030} text
{2032}{2115} text.
{2117}{2213} text
And *.srt look like this:
01
00:02:40,327 --> 00:02:51,421
text
02
00:03:01,014 --> 00:03:02,266
text
03
00:04:00,991 --> 00:04:04,995
text
04
00:04:13,378 --> 00:04:14,838
text
3. I Also have quite a few Japanese Anime in *.ogm & *.mkv file extensions that feature built-in soft subs in English which you can enable or disable using DirectVodSub.
What I would like to do is add another set of subs in Greek which I will translate & type my self. So, the Anime will feature both English & Greek built-in subs which I’ll be able to enable or disable via DirectVobSub.
Alternatively, I would like to edit the existing built-in subs of the ogm & mkv video files.
Again what would be the best tool for these tasks?
Thanks in advance.
1. The old substation alpha is still very good or subtitle workshop or check our tools section under subtitle.
2. It doesn't matter that much for text subtitles, I would use srt.
3. You make srt and then add the srt with mkvtoolnix for mkv files. I don't know how to do it for ogm files.
convert avi with subtitle files (.sub & .idx) into .m4v with soft subs?
By The Nemesis in forum Video ConversionReplies: 1Last Post: 6th Mar 2011, 20:40 -
Help -prob playing mkv w/dts&emb subs on Samsung ln40b650t1fxza LCD
By sldiri27 in forum Media Center PC / MediaCentersReplies: 1Last Post: 26th Oct 2009, 02:34 -
Help -Prob playing mkv w/dts&emb subs on Samsung ln40b650t1fxza
By sldiri27 in forum Newbie / General discussionsReplies: 0Last Post: 25th Oct 2009, 23:55 -
Full conversion MKV subs to avi subs & fonts intact.
By ashidosai in forum Video ConversionReplies: 28Last Post: 18th Oct 2008, 16:36 -
Ogm and mkv with subs in forntrow
By Senmet in forum MacReplies: 1Last Post: 13th Jul 2007, 08:46
Statistics
Newest guides
Latest tool updates
New media comments
