Hello, Happy New Year!
I am going to buy myself a standard dvd recorder (without internal hardrive) to convert my VHS tapes to DVD (I thought a Samsung DVD-R128, Argos @ £120)
A friend says all I need to do is :
1. Connect the video player to the dvd recorder using a scart lead
2. Insert the video tape into the player, insert a blank dvd into the dvd recorder, press play on the video recorder and record on the dvd recorder.
3. Make a cuppa and wait until the video has played through.
Is it really this easy?
If anybody has any thoughts or advice on this method I would love to hear them!
Also, how long (in time) is a standard 4.7gb DVD-R?
Many thanks, hope everyone has had a good few days off work!
Katie
Thread: VHS to DVD (basic questions)
I'm in the US and still don't understand this scart thing except to know it seems to cause a lot of trouble.Originally Posted by BPH2002
Possibly, if your tapes are in good shape and they are home recordings you shouldn't have any problems. What I would suggest is if the DVD player supports it get a DVD-RW disc so you can make multiple tests on the same disc. Capture some short clips preferably ones where this a lot of action. Test it, then repeat for some other setting.2. Insert the video tape into the player, insert a blank dvd into the dvd recorder, press play on the video recorder and record on the dvd recorder.
This is relative to the bitrate, a higher bitrate will give you better quality. Lower bitrate equals more time on disc but at a lower quality.Also, how long (in time) is a standard 4.7gb DVD-R?
You most likely can't set a specific bitrate with the recorder but instead it will have presets, most likely the high quality one will be for 1 hour, the next for 1.5 hours and so on so forth. As I suggested get a rewritable disc and test the different selections. The 1.5 hour selection is most likely the lowest you want to use if you want to maintain a decent quality.
If these VHS tapes are pre-recorded ones as bought in shops, it is quite possible that you will NOT be able to copy them with a dvd recorder without additional equipment.
Do a search in the forum for 'macrovision'
Hi, with out getting too technical the simple answer to your question is yes, it is that easy. As thecoalman and DB83 have already mentioned if they are commercial video tapes then there may be a problem with macro vision but if they are home movies then you should be fine. It isn't a question of how long in time a 4.7 gig disk is but what record "speed" you set your recorder to, this will be explained in the manual, simply find out how long the video on the tape is and set your DVD recorder to the nearest speed you can. If the DVD recorder has front phono connections (red white and yellow) it may be easier to use these and not a scart that way you wont be scrambling behind your recorder all the time if you want to connect the DVD recorder to a sky or cable box, I don't know if you have that set up of course
but make sure on the recorder you select the correct source for your recording
Get a stabilizer: http://www.checkhere22.com/stabilizer/
This device will defeat Macrovision and allow VHS to DVD recording to continue.
Woah, VHS encryption (is that the right word?)
Didn't see that one coming, I just presumed there would be no problems.
Luckily the majority of my VHS tapes are home movies and very low budget event tapes that I doubt will have the macrovision problems of a Warner Brothers tape of Spiderman, for example.
Very interesting, thanks very much for the comments and the heads up.
Helpfull place, thanks again.
Katie
basic video questions
By Dan K in forum Newbie / General discussionsReplies: 17Last Post: 2nd Jan 2009, 16:59 -
Some Basic HD Television Questions
By Maikeru-sama in forum Newbie / General discussionsReplies: 29Last Post: 6th Jul 2008, 11:02 -
Basic FFMpeg Questions
By Maikeru-sama in forum Video ConversionReplies: 8Last Post: 7th Jun 2008, 09:33 -
Basic questions - PowerPoint to WMV to connect with AVI files to make DVD
By epotereiko in forum Newbie / General discussionsReplies: 0Last Post: 20th Apr 2008, 12:56 -
ConvertXToDVD, MPlayer and TMPGenc DVD Author 3 basic Questions
By Maikeru-sama in forum Video ConversionReplies: 4Last Post: 28th Jan 2008, 10:43
