First id like to say a very happy new year to one and all.
i just got the panny dmr-ez27 as my dmr-e50 was starting to get a bit glitchy.
i use TMPgenc dvd author ver 1.5.15.49 to get dvd ram recordings onto my computer
for editing and then re-burn to dvd-r.
the problem i've encountered with the new recorder is there does not seem to be
any option to set the hybrid vbr resolution to fixed which is required by the version of TMPgenc dvd author
that i am using.
am i missing something in the panny menu ?
or do i need to upgrade my version of TMPgenc dvd author ?
is there some other way around the problem ?
many thanks for any help in advance.
wake up this planet is dying!
Hi.
This option was removed from later models, I believe.
What about using DVD-RW in video mode?
Is that no good? Or is it because you want to use RAM?
I use a JVC RAM capable recorder, but always use DVD-RW and TMPG Author 2.0.
I've only had a problem with 1 or 2 discs that changed the resolution in the middle of recording. I did have a problem with InCD and TMPGEnc. After uninstalling InCD, no more problems.
I am thinking of purchasing this player/recorder for this purpose. Did you get the issue resolved?Originally Posted by hamilton accie
Panasonic DMR-EZ27 and EZ28 switches channels while recording
By dtsb52 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Jul 2009, 11:59 -
Panasonic DMR-EZ27 has lost its digital tuning capability
By Frank-0-Video in forum DVD & Blu-ray RecordersReplies: 13Last Post: 23rd Feb 2009, 17:26 -
Panasonic DMR-EZ27 Chip set?
By Deter in forum DVD & Blu-ray RecordersReplies: 5Last Post: 17th Sep 2008, 17:26 -
Panasonic DMR-EZ27 recording audio problem
By manlok in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Mar 2008, 21:02 -
Panasonic LSI for DMR-EZ17,EZ27...?
By cosmin in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Aug 2007, 21:17
