VideoHelp.com Forum
Results 1 to 30 of 31
    Hello,
    i have a new receiver, its the kathrein ufs 910, it is a HD receiver which althogh allows me to record hd streams on an extern hdd. it splitts the file in 2 gig parts because the harddisk have to format as fat 32.
    the files are saved in a kind of a ts stream called, trp.
    so i first join them, then i use tsremux to make them as real ts streams.
    then i would like to encode the stream to 720p in x264 with the ac3 stream in an mkv container.
    but every tool or programm i wanted to use was faild to convert the ts stream.
    when i record a non hd show, i can convert it with staxrip or what tool i want to use.
    Codec : AVC
    Codec/Info : MPEG-4 AVC
    Codec profile : Main@L4.0
    Breite : 1920 Pixel
    Höhe : 1088 Pixel
    Bildseitenverhältnis : 16/9
    can anyone help me?
    thank you.
    greets korn hulio
    Try installing Haali media splitter.
    with taht tool, i can see qhat is include that ts conatiner, but when i click encode to xvid, it stands at 0,0% all the time, without an error message. allthough i would like to cut a few minuts at the beginning of the movie.
    After installing Haali can you play the ts file with Windows Media Player?
    no i can not
    It sounds like you now need an h.264 decoder. I believe Staxrip uses VFW so you can try downloading ffdshow and use its x264 decoder and encoder.
    i have installed the h264 codec, but it still don't work
    only VLC show the right resolutiuon, but don't start with the movie
    VLC does its own file parsing, decompression, etc. So it doesn't require (or even use) installed VFW or DirectShow codecs. It's rather perplexing that VFW won't play your file.
    Maybe you could post a short (5 or 10 seconds) sample recording and someone can take a look at it.
    ok thank you i try to split it
    http://rapidshare.com/files/80736302/asd.ts.html
    ok with a tool called avidemux i could splitt a small part of it.
    and i was even able to watch it in media player classic
    The file you uploaded has a .ts extension (mpeg transport stream) but it is an AVI file. I don't think it's really representative of your source.
    h.264 is rather difficult to handle with VFW. You might try using AviSynth's DirectShowSource() filter and opening the AVS script in Staxrip.
    yes i know ist h264 inside. it is from a dvb-s2 source.
    ok i try to use this why. but tomorror, i have to go now. but thank you for your help.
    avidemux had no problems encoding your sample
    just set audio to "copy" (it was already AC3), container to MKV, and video to x264 (and adjust the settings like bitrate, #passes, etc...)
    I had a "preview" of 2.4 installed and it didn't have an MKV output option. I removed it and installed the final 2.4 release and it does indeed support MKV output.
    ok so i have tried, to encode it with avidemux, i made all settings and start to ence, but after one minuth there comes a message, that there was a fatal error but there is no file output with a message what is wrong
    does anyone know a homepage where i can upload the debug text
    Just paste or attach it into a post here.
  18. Member
    ok this is the crash.js
    //AD  <- Needed to identify//
    //--automatically built--
    //--Project: C:\Documents and Settings\yxc\avidemux/crash.js
    var app = new Avidemux();
    //** Video **
    // 01 videos source
    app.load("O:/htdv_work/h264.ts.idx");
    //01 segments
    app.clearSegments();
    app.addSegment(0,0,205504);
    app.markerA=3134;
    app.markerB=186881;
    app.rebuildIndex();
    //** Postproc **
    app.video.setPostProc(3,3,0);
    app.video.setFps1000(0);
    //** Filters **
    app.video.addFilter("crop","left=0","right=0","top=0","bottom=8");
    app.video.addFilter("mpresize","w=1280","h=720","algo=0");
    //** Video Codec conf **
    app.video.codec("X264","2PASS=4073","188 00 00 00 00 00 00 00 00 00 00 00 00 28 00 00 00 1e 00 00 00 3c 00 00 00 0a 00 00 00 33 00 00 00 04 00 00 00 01 00 00 00 28 00 00 00 19 00 00 00 fa 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 01 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 01 00 00 00 00 00 00 00 04 00 00 00 10 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5a 00 00 00 ");
    //** Audio **
    app.audio.reset();
    app.audio.codec("copy",128,0,"");
    app.audio.normalizeMode=0;
    app.audio.normalizeValue=0;
    app.audio.delay=0;
    app.audio.mixer("NONE");
    app.setContainer("MATROSKA");
    setSuccess(1);
    //app.Exit();
    //End of script
    and here the stdout.txt
      Avidemux v2.4 (r3731)
     http://www.avidemux.org
     Code      : Mean, JSC, Gruntster
     GFX       : Nestor Di , nestordi@augcyl.org
     Design    : Jakub Misak
     FreeBSD   : Anish Mistry, amistry@am-productions.biz
     Audio     : Mihail Zenkov
     MacOsX    : Kuisathaverat
     Win32     : Gruntster
    Compiler: GCC 4.2.1
    Build Target: Microsoft Windows (x86)
    User Interface: GTK+ (2.10.14)
    Operating System: Microsoft Windows XP Professional Service Pack 2 (5.1.2600; 32-bit)
    Initialising prefs
    Directory C:\Documents and Settings\yxc\avidemux exists.Good.
    Using C:\Documents and Settings\yxc\avidemux as base directory for prefs/jobs/...
    Preferences found and loaded
    [cpuCaps]Checking CPU capabilities
    		MMX detected
    		MMXEXT detected
    		SSE detected
    		SSE2 detected
    		SSE3 detected
    		SSSE3 detected
    [cpuCaps]End of CPU capabilities check (cpuMask :ffffffff)
     Registering Encoders
    MJPEG encoder registered
    Xvid-4 encoder registered
    FFmpeg encoder registered
    3 encoder(s) registered
    [SDL] Version: 1.2.12
    [SDL] Setting video driver to Microsoft Windows GDI
    [SDL] Initialisation succeeded
    [SDL] Video Driver: windib
    Initializing WinSock
    WinSock ok
    [Locale] setlocale German_Germany.1252
    [Locale] Textdomain was messages
    [Locale] Textdomain is now avidemux
    [Locale] Test: _Datei
    Initializing Dithering tables
    [xvid] Initializing global Xvid 4
    [xvid] Build: xvid-1.2.0-dev
    [xvid] SIMD supported: (1cf)
    		MMX
    		MMXEXT
    		SSE
    		SSE2
    Found 19 video encoder
    Found 10 audio encoder
    Found 13 Format
    Directory C:\Documents and Settings\yxc\avidemux\custom exists.Good.
    No custom script
    Found 0 custom scripts, adding them
    Menu built
    The screen seems to be 1440 x 870 px
    Initializing postproc
    Deleting post proc
    updating post proc
    Enabled type:3 strength:3
     Registering Filters
    Using dummy audio device
    Unable to load [libamrnb-2.dll]: The specified module could not be found.
    Unable to load [libdts.dll]: The specified module could not be found.
    Spidermonkey initialized.
    Spidermonkey compiling "C:\Documents and Settings\yxc\avidemux/crash.js"...Done.
    Spidermonkey executing "C:\Documents and Settings\yxc\avidemux/crash.js"...Loading "O:/htdv_work/h264.ts.idx"
    594d4441 -> 594d4441
     New mpeg index file detected..
      opening d2v file : O:/htdv_work/h264.ts.idx
    For file :O:/htdv_work/h264.ts
    Pic      :1920x1088, 25000 fps
    #Gop     :5176
    #Img     :205504
    Ts: Using 1011 as pid for track 0
    Creating mpeg TS demuxer  main Pid: 1011 , pes id :0, packet size=188
    There was several files, but dont append was forced
    Simple loading:
     file: O:/htdv_work/h264.ts, size: 3222757820
     found 1 files
    Done
    Dropping 0 last B/P frames
     Creating start sequence (1505880)..
    Mmm cound not find a gop start.....
    Reordering mpeg frames
    Renumbered Gop  1 /5176
      opening dmx file for audio track : O:/htdv_work/h264.ts.idx
    Ts: Using 1100 as pid for track 0
    Creating mpeg TS demuxer  main Pid: 1100 , pes id :0, packet size=188
    Simple loading:
     found 1 files
    Done
    Building index with 5176 sync points
    Filling audio header
    Audio index loaded, probing...
    Probing track:0, pid: 1100 pes:0
     Syncing on 16384
    Sync found at offset 0
     Syncing on 16384
    Probing track:1, pid: 1101 pes:0
     Syncing on 16384
     Syncing on 16384
     DMX audio initialized (457895424 bytes)
    With 5176 sync point
    Mpeg index file successfully read
    Deleting post proc
    Deleting post proc
    updating post proc
    [Editor] Duration in seconds : 8220 , in samples : 0
     Decoder FCC: H264 (34363248)
    Searching decoder (1920 x 1088, extradataSize:0)...
    [lavc] Build: 3352580
    [lavc] Initializing H264 decoder with 0 extradata
    [lavc] Decoder init: CODEC_ID_H264 video decoder initialized!
     checking for B-Frames...
    [lavc] Err: 32024, size: 32024
    [lavc] error in FFMP43/mpeg4!: got picture
     ***oops***
    [lavc] Err: 28470, size: 28470
     ***oops***
    [lavc] Err: 67257, size: 67257
     ***oops***
     * Frame 5 is A B frame, flag not ok
     * Frame 7 is A B frame, flag not ok
     * Frame 8 is A B frame, flag not ok
     * Frame 10 is A B frame, flag not ok
     * Frame 11 is A B frame, flag not ok
    [lavc] Err: 73286, size: 73286
     ***oops***
     * Frame 17 is A B frame, flag not ok
     * Frame 19 is A B frame, flag not ok
     * Frame 20 is A B frame, flag not ok
     * Frame 22 is A B frame, flag not ok
     * Frame 23 is A B frame, flag not ok
     * Frame 25 is A B frame, flag not ok
     * Frame 26 is A B frame, flag not ok
     * Frame 28 is A B frame, flag not ok
     * Frame 29 is A B frame, flag not ok
     * Frame 31 is A B frame, flag not ok
     * Frame 32 is A B frame, flag not ok
     * Frame 34 is A B frame, flag not ok
     * Frame 35 is A B frame, flag not ok
     * Frame 37 is A B frame, flag not ok
     * Frame 38 is A B frame, flag not ok
     * Frame 40 is A B frame, flag not ok
     * Frame 41 is A B frame, flag not ok
     * Frame 43 is A B frame, flag not ok
     * Frame 44 is A B frame, flag not ok
     * Frame 46 is A B frame, flag not ok
     * Frame 47 is A B frame, flag not ok
     * Frame 49 is A B frame, flag not ok
     Mmm this appear to have b-frame...
     But the  index is not up to date
    [lavc] Hurry up
    ??0x7
    ??0x6
    ??0x6
    .[errased very mutch by my self]
    ??0x6
    [lavc] full decoding
     End of B-frame check
     Editor :Audio streamer initialized
     Audio codec:  AC3
    [GTK] Changing size to 1920 1088
    [GTK] Changing size to 960 544
    [lavc] Err: 39722, size: 39722
    Editor: Last Decoding2 failed for frame 0
    ** conf updated **
    clearing segments
    [Editor] updating soundtracks duration
     Syncing on 8192
    A52 sync found at 0 + 0
     Syncing on 8192
     trying to sync on frame 205504
     trying to sync on frame 204418
    DMX_audio Going out of bound (position : 457894080 asked 8192 end457895424)
    Cannot read enough bytes!
     trying to sync on frame 204417
    DMX_audio Going out of bound (position : 457891840 asked 8192 end457895424)
     trying to sync on frame 204416
    DMX_audio Going out of bound (position : 457889600 asked 8192 end457895424)
     trying to sync on frame 204415
    DMX_audio Going out of bound (position : 457887360 asked 8192 end457895424)
     trying to sync on frame 204414
     Syncing on 8192
    Sync found at offset 1344
    A52 sync found at 457885120 + 1344
     Syncing on 8192
     Audio start : 0 end : 457886464 size : 457886464
     Syncing on 8192
     Syncing on 8192
     Syncing on 8192
     Syncing on 8192
    Deleting post proc
    updating post proc
    Fps too low
    Done.
     configuring codec :18
    Video duration :7350
    Track1 bitrate :448
    Track2 bitrate :0
     Canonizing null string ??? (C:\Documents and Settings\yxc\Desktop\avidemux_2.4_win32\)
     2 tag
     36 tag
     found : 2 filters
    **saving:**
    Output format:11
     AVI family
    [x264] using I:\hdtv_work\ewiger.stat as logfile
    [x264] Encoder ready, w: 1280 h: 720 mode: 3[x264] pass 1
    [x264] codec using I:\hdtv_work\ewiger.stat as statfile
    [x264] Opening x264 for 1280 x 720
    [x264] vui.i_sar_width = 1
    [x264] vui.i_sar_height = 1
    [x264] rc.f_qcompress = 0,60
    [x264] rc.i_vbv_max_bitrate = 0
    [x264] rc.i_vbv_buffer_size = 0
    [x264] rc.f_vbv_buffer_init = 0,90
    [x264] analyse.b_fast_pskip = 0
    [x264] analyse.b_dct_decimate = 1
    [x264] b_interlaced = 0
    [x264] analyse.i_direct_mv_pred = 1
    [x264] rc.i_qp_min = 10
    [x264] rc.i_qp_max = 51
    [x264] rc.i_qp_step = 4
    [x264] i_frame_reference = 1
    [x264] i_scenecut_threshold = 40
    [x264] i_keyint_min = 25
    [x264] i_keyint_max = 250
    [x264] i_bframe = 2
    [x264] i_bframe_bias = 0
    [x264] b_bframe_pyramid = 0
    [x264] analyse. b_bidir_me = 0
    [x264] b_bframe_adaptive = 1
    [x264] analyse.b_weighted_bipred = 0
    [x264] b_cabac = 1
    [x264] analyse.i_trellis = 0
    [x264] analyse.i_subpel_refine = 2
    [x264] analyse.b_chroma_me = 1
    [x264] b_deblocking_filter = 1
    [x264] i_deblocking_filter_alphac0 = 0
    [x264] i_deblocking_filter_beta = 0
    [x264] analyse.i_me_method = 0
    [x264] analyse.i_me_range = 16
    [x264] analyse.b_transform_8x8 = 0
    [x264] analyse.b_mixed_references = 0
    [x264] analyse.i_noise_reduction = 0
    [x264] VBV_max_br = 0
    [x264] vbv_buffer_size = 0
    [x264] f_vbv_buffer_init = 0,900000
    [x264] init ok (atom mode: 1)
    [x264] using threads
    [x264] Nb nal: 3
    [x264] Unknown image type: 0
    [lavc] Err: 2963, size: 2963
    Editor: Last Decoding2 failed for frame 3136
    Pass 1 prefill : 7
    [lavc] Err: 18724, size: 18724
    Editor: Last Decoding2 failed for frame 3164
    [lavc] Err: 28981, size: 28981
    Editor: Last Decoding2 failed for frame 3209
    [lavc] Err: 30440, size: 30440
    Editor: Last Decoding2 failed for frame 3257
    [lavc] Err: 34471, size: 34471
    Editor: Last Decoding2 failed for frame 3305
    [lavc] Err: 89561, size: 89561
    Editor: Last Decoding2 failed for frame 3353
    [lavc] Err: 68458, size: 68458
    Editor: Last Decoding2 failed for frame 3401
    [lavc] Err: 18187, size: 18187
    Editor: Last Decoding2 failed for frame 3436
    [lavc] PAFF interlacing is not implemented
    [lavc] concealing 4080 DC, 4080 AC, 4080 MV errors
    [lavc] Err: 17178, size: 17178
    Editor: Last Decoding2 failed for frame 3442
    [lavc] illegal short term buffer state detected
    Saving crash file to C:\Documents and Settings\yxc\avidemux/crash.js
     **Saving script project **
    Conf size : 188
    *********** EXCEPTION **************
    Registers:
    EAX: 00001E80  EBX: 16F85C40  ECX: 00000F40  EDX: 00000008  ESI: 09B92840
    EDI: 00000110  ESP: 0021F734  EBP: 00000000  EIP: 0058DBEF  EFlags: 00010202
    Exception Code: EXCEPTION_ACCESS_VIOLATION (C0000005)
    Exception Flags: 00000000
    Origin:
    C:\Documents and Settings\yxc\Desktop\avidemux_2.4_win32\avidemux2_gtk.exe(add_pixels_clamped_mmx+0x18DBEF) [0x0058DBEF]
    *********** BACKTRACE **************
    Frame  0: C:\Documents and Settings\yxc\Desktop\avidemux_2.4_win32\avidemux2_gtk.exe(Z16exceptionHandlerP17_EXCEPTION_RECORDPvP8_CONTEXTS1_+0x10F8EE) [0x0050F8EE]
    Frame  1: C:\WINDOWS\system32\ntdll.dll(RtlConvertUlongToLargeInteger+0x37BF) [0x7C9037BF]
    Frame  2: C:\WINDOWS\system32\ntdll.dll(RtlConvertUlongToLargeInteger+0x378B) [0x7C90378B]
    Frame  3: C:\WINDOWS\system32\ntdll.dll(KiUserExceptionDispatcher+0xEAFA) [0x7C90EAFA]
    Cleaning up
    [lavc] Destroyed
    Deleting post proc
    Waiting for Spidermonkey to finish...
    Cleaning up Spidermonkey.
    [SDL] Quitting...
    End of cleanup
    Images stat:
    ___________
    Max memory consumed (MB)     : 49702
    Current memory consumed (MB) : 8235
    Max image used               : 18
    Cur image used               : 4
    Global mem stat
    ______________
    	Memory consumed: 14 (MB)
    Goodbye...
    It looks like your source video uses PAFF which is apparently not supported by AviDemux. Programs that don't support PAFF often crash when it's encountered.
    CoreAVC supports PAFF and I believe the latest ffdshow does too. But I don't know if there's any way to coerce AviDemux into using an external decoder.
  21. Member Kayembee's Avatar
    Wouldn't Avisynth work? Just pass a 1-line script, "DirectShowSource("source")", to AviDemux.
  22. Member
    The knowledge of encoding, decoding on this site is far greater than my own so excuse me if this is not related.
    I saw that you were trying to encode to H.264 and that at one point it said FFmpeg was listed and that your processor allows SSSE3.
    I do know that after a certain version there seems to be a problem with H.264 and a few dual core processors. Some work, some don't My Core 2 Duo and a Pentium D. What happens when I test it is that it starts to encoded, or starts the encoding procedure but then it crashes.
    This thread describes the issue, and this thread will tell you what was the last version of FFmpeg that was known to work. I have posted in the tread and they list what versions I tested as well. I go them from the mirror download here.
    http://arrozcru.no-ip.org/ffmpeg_for...opic.php?t=621
  23. Member
    That's what I thought but AviDemux doesn't seem to open AVS scripts. Maybe someone who knows the program better than I do can give instructions.
  24. Member
    To use Avidemux with AVS scripts, you have to use avsproxy
    1) Start "AVS Proxy GUI" (through the start menu => avidemux programs menu)
    2) Load up your AVS script
    3) Startup avidemux, under file there is an option "connect to avs proxy"
    I find this process alot slower (added steps and processing wise) than using avisynth & vdub
    @jagabo - why do you think avidemux isn't able to process the entire original source? It is able to cut a clip and encode that....I'm not following why it shouldn't be able to do the entire source video?
  25. Member
    In Copy (remux) mode AviDemux doesn't have to decompress the frames and hence never sees the PAFF. To resize and reencode it must first decompress the frames.
  26. Member
    I don't understand all the expert programming jargon or what PAFF is, I'm just trying to learn some stuff here...
    Why not cut off a "clip" that is 99.99% of the original source and encode that?
    How does the clip that kornhulio provided differ from the original source (besides file length)?
    or is there something else that I'm missing?
  27. Member
    Why not cut off a "clip" that is 99.99% of the original source :) and encode that?
    Looking at the log that was posted, the first frame with PAFF is #3436:
    Maybe the AVI file that was posted didn't include any of the frames with PAFF.
    PAFF and MBAFF: http://forum.doom9.org/showthread.ph...647#post927647
    By the way, I was unable to find the AVS Proxy GUI at first. So I uninstalled AviDemux and resinstalled it. It was then that I saw Avi Proxy GUI wasn't installed by default. This might help the OP.
  28. Member
    ok thank you for all your post, i do want to convert only a part of it, the comercial at the beginning and the end i even cutted with avidemux.
    i try it with avs
  29. Member
    it don't load it in, there is the msg:
    AvsSocket Proxy, derivated from avs2yuv by Loren Merritt
    Loading Avisynth.dll
    Avisynth.dll loaded
    Env created
    Importing..
    Avisynth error:
    DirectShowSource: Could not open as video or audio.
    Video returned: "DirectShowSource : Timeout waiting for graph to start."
    Audio returned: "DirectShowSource : Timeout waiting for graph to start."
    (O:\htdv_work\film.avs, line 1)
    WinSock ok
    Socket bound to port 9999
    Waiting for client to connect...
    Client connected.
    Received get info...
    and so it stays... for about one hour now
  30. Member
    Works for me...
    Avisynth.dll loaded
    Env created
    Importing..
    179702691 / 5996080
    Info
    Width :640
    Height :480
    Fps1K :29971
    NbFrame :82807
    WinSock ok
    Then after connecting the the proxy it continues with
    Client connected.
    Get frame 0 (old:4294901760)
  1. Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
    By doctormelodious in forum ffmpegX general discussion
    Last Post: 4th Jul 2010, 08:12
  2. I can't figure out how to use the h.264 (x264) codec!
    By Tahlos in forum Newbie / General discussions
    Last Post: 15th Jun 2010, 18:34
  3. x264 doesn't encode h.264
    By thuriel in forum Mac
    Last Post: 20th Oct 2009, 14:09
  4. X264 or H.264
    By user123456 in forum Newbie / General discussions
    Last Post: 25th May 2009, 16:21
  5. X264 HDTV question
    By JConnor in forum Newbie / General discussions
    Last Post: 29th Sep 2007, 15:44
