please could someone help as this driving me mad
i have panasonic tv
bush dvd video recorder
when i try to play dvd or videos the picture is green
i have tried sanyo dvd video redcorder whith the same scart leads it works fine in the panosonic
then i tried the bush dvd video recorder on a samusung tv picture is ok
have spoken to panasonic they said make sure the video is set to rgb output the video
must be set to rgb output as it whould not work on my samsung tv
i have been using the same scart leads
please help it is driving me mad
Hardware model numbers and connection types would be helpful. As I'm not from over the pond, I'm not too familiar with scart. But the problem doesn't sound cable related, but video setup related as referenced by Panasonic. The dvd recorder should allow you to change the video output type. Depending on the player, you should have settings for composite, RGB, and S-video. If it doesn't, then you will have to return it and get a different model.
Google is your Friend
Panasonic DVD Recorder - Spindle needs cleaning
By lacywest in forum DVD & Blu-ray RecordersReplies: 30Last Post: 20th Oct 2014, 23:20 -
Panasonic E25S dvd recorder sometimes no sound, sometimes the language is
By padraig in forum DVD & Blu-ray RecordersReplies: 2Last Post: 8th May 2010, 19:18 -
Bush combi Video + DVD recorder
By debrag in forum DVD & Blu-ray RecordersReplies: 1Last Post: 31st Dec 2007, 10:11 -
Panasonic DVD Recorder, no multi region, what to do?
By girl_alliene in forum DVD & Blu-ray RecordersReplies: 2Last Post: 20th Sep 2007, 10:43 -
Panasonic or Pioneer DVD recorder with HDD
By jackedup in forum DVD & Blu-ray RecordersReplies: 7Last Post: 27th Jul 2007, 10:41
