Hi, just wondering if anyone out there owns the Apex AD1250X DVD player? I have one and have been having a wee bit of trouble using it to play DIVX/XVID/Mpeg-4 Files. It plays 30% of any files I download and burn no problem.
The problem videos appear on my television bigger than the viewable area. For example, the titles, subtitles, etc are too big for the screen. Wondering what resolution I should convert these files to using the DIVX converter?
Any other tips or advice for this player? It has great potential if I can figure out this problem.
Thanks!!!!
thanks for the reply. this is happening with a lot of XVID encoded videos of all types, don't know about hentai. When I look at the ones that don't work they have many different resolutions. I guess I will have to begin to slowly log what works and doesn't work? That's fine but I was hoping to find out what is the best resolution that fits the screen. I am afraid if I just use what worked on another video I will lose quality.
It's an overscan issue (all TVs generally overscan to some extent). Unless you pad the video with a black border (at least, on the top and bottom, you're probably going to see some of the video 'cut off' on one or more sides. If you just resize, your player will probably rescale the video to fit the screen, anyway, and you'll be right back where you started.
slingbox owners? are you happy?
By buzzinhornets in forum Media Center PC / MediaCentersReplies: 4Last Post: 18th Mar 2011, 07:33 -
Sony SMPU10 owners
By MJA in forum Media Center PC / MediaCentersReplies: 0Last Post: 26th Nov 2009, 08:48 -
Tutorials for new Mac owners?
By nufanboy in forum MacReplies: 3Last Post: 12th Dec 2008, 11:04 -
APEX AD1250X stuck in PAL mode cant switch back
By sysman0 in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 22:04
