VideoHelp.com Forum
    I just wonder how much time AGK uses for you when converiting DVD to .avi?
    I have a P4 3.4Ghz, 2GB RAM, and the computer newly re formatted.
    Still a convert takes from 4-6 hours.
    The last one took over 11 hours. This can't be right.
    I use the advaced mode with fix width at 720, otherwise the movie gets to small on the screen.
    But before when I used auto with, no conversion took less than 4 hours.
    Should it take so much time???
    I've been trying to prepare to files from the DVD with Gordian Knot, see the steps, untill using v-strip. it takes like 15-20 min or so. Then you'll get a single VOB file which you can put in gordian knot.
    Then the .avi is ready in less than 2 hours.
    Super.
    Ok I asked the quesiton myself and answeared myself, not that happens so much...
    Nope, I was wrong, I was by mistake using a decoded file. So it won't get ready faster than 5 hours...
  4. Member mats.hogberg's Avatar
    I usually (on a P IV 3.2 GHz) get around realtime (around 30 fps) for DVD to AVI with AutoGK (per pass - If I do 2 pass, a 2 hour move would take 4 hours or a little less.). I use the auto width option.
    /Mats
    hmm, maybe the fact that I use 720 in width make it go a little slower
    so less than 4 hours is not possible then...
  1. AGK Batcher v1.01 Released
    By OneAmp in forum DVD Ripping
    Last Post: 24th Nov 2010, 09:35
  2. Replacement for AGK?
    By OldAmateur in forum Video Conversion
    Last Post: 1st Aug 2010, 15:47
  3. audio sync with AGK
    By coeng73 in forum Blu-ray Ripping
    Last Post: 28th Oct 2009, 21:17
  4. AGK conversion problems
    By loninappleton in forum Subtitle
    Last Post: 9th Sep 2009, 10:48
  5. Replies: 44
    Last Post: 15th Jun 2007, 08:14
