Hi i have a bush combi that copies to dvd+r/+rw . what i need to do is copy various clips from a dozen or so VHS tapes. Could i play one tape clip .Then insert another tape and resume copying without loosing initial recording on a dvd+r . Or what advantage or not do i have to use dvd+rw Which way should i go i need educating on this subject
regards pat
Yes, most recorders I know of allow you to Pause a recording, load another tape, find the spot, and press Pause again to restart the recording.
For speedier assembly, I'd run all the tapes to the 1st point you want to copy?
The only thing the +RW is going to give you, is the ability to delete something recorded, and gain back that time on the DVD.
And play it in a DVD player without finalizing. Have not tried DVD+R though if it plays.
Yes +R's need to be finalized, +RW's dont need to be finalized, but on my Panny's anyway, they need to be "made compatable" otherwise they will not have a top menu on any player except the Panny recorder.
With my Liteon recorder, the top menu (unfinalized DVD+RW) is visible when played in another player. However, when I delete a clip, it does not seem to gain space.
Sorry I should have been more specific. If a person deletes the LAST recorded item, you should gain back all your time, that the last item took up. Although on my Panny's even if I delete a item other than the last item, I do gain back some portion of time, just not all. Same for -RW's.
Funny thing about the menu thing. I dont think Panny's really like + discs. Oh it will record to them, but they also have problems with search speeds on + discs. I am missing the fastest 2 speeds when using + discs. Although once I finalize the +R discs, then I get back the 2 fastest search speeds, but never on +RW's. Hence I hardly use + discs in my Panny's.
Pioneer 660h dvd recorder - problem copying
By thebiglad30 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 25th Oct 2009, 15:09 -
DVR to DVD recorder copying
By Boltsfan22 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 18th Oct 2008, 16:02 -
JVC D-VHS HD Recorder Question
By nlec in forum DVB / HDTVReplies: 0Last Post: 17th Oct 2008, 19:03 -
copying standard 8mm tapes to DVD recorder
By mjwhite in forum DVD & Blu-ray RecordersReplies: 2Last Post: 31st Dec 2007, 13:14 -
ATSC Tuner Question with DVD Player/Recorder/VHS Combo Unit
By Surfmaster in forum DVB / HDTVReplies: 4Last Post: 17th Dec 2007, 20:01
