    Jul 2002
    I have been playing around with vlc and can't seem to make the settings stay.
    I click on settings->extended gui->enable->brightness(slider) and then play a
    video for which the settings have no effect. The settings all return back to default.
    How can I make the settings permanent.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    I don't know if you can for the extended GUI, but you can change the image properties filter in 'Preferences' and it should stay after clicking, 'Save'.
    Oh, and I almost forgot, make sure you put a 'checkmark' in the top filter menu for 'Image Properties Filter' to activate it. It's in the box right above the 'image adjust' that's highlighted.
    Jul 2002
    Thanks redwudz,
    Your reply helped a lot. Is there a guide or manual anywhere?
  4. Mod Neophyte Super Moderator redwudz's Avatar
    USA
