Hi everyone:![]()
My laserdisc player only has 2 RCA audio outs. Consequently, when I tranfered my laserdiscs onto DVDs with my Philips DVD recorder, the sound was recorded in Dolby Digital Stereo, even though many laserdiscs of mine were manufactured with Dolby Digital AC3 (Surround).
Now, I read that TMPGEnc has its own AC3 Plug-in that can decode and encode sound in AC3 and that can be used with their DVD authoring software.
My question is:
Can this TMPGEnc AC3 Plug-in re-encode the Dolby Digital Stereo sound of some of my DVDs that I recorded from my AC3 laserdiscs? Will the sound be true AC3 or will it be only simulated AC3, like the fake & cheap simulated stereo sound of those CDs re-mastered from 78 rpms and some 33-1/3 and 45 rpms?
Dolby Digital is AC3. Dolby ProLogic (Stereo) was the analogue process.
Dolby Digital (AC3) can have 1 - 7 channels of audio, giving you 1.0 through to 6.1 audio. If you recorded from the analogue outputs of your laser disc player then you have only recorded the stereo downmix of the original audio. Even if the original was encoded as 5.1 AC3, you have lost all the information required to rebuild the mix.
Tmpgenc's plugin is only capable of encoding to 2.0 AC3, so it won't help you. DAudioK has a 5.1 upmix capability that may give you enough of a simulated mix to make you happy. Worth a look. Soopafresh also has some scripts to do a similar thing. Search the audio forum for them.
Thanks, guns1inger. That clarified my confusion. I'm glad I have not bought the plug-in yet.If you recorded from the analogue outputs of your laser disc player then you have only recorded the stereo downmix of the original audio. Even if the original was encoded as 5.1 AC3, you have lost all the information required to rebuild the mix.
Dolby Digital PLus (ac3) track to FLAC error
By Edgarke16 in forum AudioReplies: 0Last Post: 26th Sep 2011, 23:38 -
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 19:51 -
Splitting AC3 Dolby Digital 2.0 (surround) into seperate WAVs?
By Asaki in forum AudioReplies: 2Last Post: 29th Apr 2011, 14:18 -
Difference Between DTS 5.1 & Dolby Digital AC3 5.1
By dorababu in forum AudioReplies: 6Last Post: 30th Nov 2010, 01:41 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 16:54
Statistics
Newest guides
Latest tool updates
New media comments
