Hi Guys,
No doubt 5982 is a great DVD player. I brought it for $54 ( incl tax and shipping) .
The problem is USB
1) 4 GB Kingston pen drive works great.
2) Seagate 500 GB too works fine.
3) WD 120 GB passport doesnt work.. Can somebody help how can I make it work ?
I formatted in FAT32 ..even tried single partition as well as multi partition , no success .
I checked the drive it seems the motor is not running ...its unable to draw current from the DVD player USB port ...
Any help guys?
Thread: Philips 5982 and USB
try to look for help here http://forum.videohelp.com/topic301465.html
FEW TIPS TO TRY
check the health of the HD using WD software just to make sure the drive is fine
http://support.wdc.com/download/inde...&pid=35&swid=3
try using Swissknife to formate your HD (1 partition)
Hello Friends,
Finally I got a solution to make Passport HDD work; Philips DVD player doesnt supply much power from its USB port so these passport mechanical drives cant work.
Get this cable from somewhere. I borrrowed from my friend.
http://www.amazon.com/gp/product/ima...&s=electronics
This has two USB ( male A Type )
POWER
POWER+DATA
Put the POWER one to laptop and the other one to DVD player and this way it would work.
The second thing I'm gonna try is
1) Take mobile charger( Moto Razr) which has mini -A connector on other end.
2) Get a mini USB receptor -to- A type receptor. I didnt find any cable still searching....
4) Connect and this way u dont need Laptop to power the drive.
Seems like less hassle and aggravation to just get a HDD that will work with the player.
Google is your Friend
[Release] Philips 5982 Modded Firmware v0.4 (w/USB Long Filename!)
By shadow_cruiser in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Jul 2008, 05:12 -
Philips DVP5960 or 5982?
By siskiou in forum DVD & Blu-ray PlayersReplies: 11Last Post: 20th Apr 2008, 21:28 -
philips 5982 divx usb problems
By fredwilson in forum Newbie / General discussionsReplies: 7Last Post: 15th Feb 2008, 22:42 -
philips 5982 with a better remote possible?
By wkk in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Sep 2007, 22:32 -
My DVDs play 2x on Philips 5982
By Gritz in forum Newbie / General discussionsReplies: 0Last Post: 21st Sep 2007, 20:57
Statistics
Newest guides
Latest tool updates
New media comments
