Here's my situation: My new LCD TV (westinghouse w4207) has a DVI-D slot. My video card, however, has a DVI-I slot. If I use a DVI-D cable, can I plug it into my DVI-I Slot in my video card? Would the signal be worse than if my video card had a DVI-D slot? If so, how much worse? Finally, since my TV and PC support the "dual link" cables, should I buy those instead of the "single link" cables?
Using a DVI-D should work fine. DVI-I has additional pins for analog video but the digital pins are the same.
http://en.wikipedia.org/wiki/DVI
I believe a dual link DVI cable would add the ability to use 1920x1080p60. But your TV probably doesn't suppport that resolution so a single link cable will do. A dual link cable won't hurt as long as both devices have a dual link connector.
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 08:31 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 19:32 -
Question about DVI-D & DVI connections ?
By VEBouto in forum ComputerReplies: 2Last Post: 27th Oct 2010, 08:28 -
DVI to HDMI giving me MAJOR quality loss!
By bilbob42 in forum Newbie / General discussionsReplies: 9Last Post: 4th Sep 2009, 23:21 -
Computer DVI output to TV DVI input
By superdud1400 in forum DVB / HDTVReplies: 12Last Post: 13th Jul 2008, 09:44
Statistics
Newest guides
Latest tool updates
New media comments
