Hi! I have been trying to figure out how to get my SE W810i to play MP4 videos at the full screen size. The screen is 176x220, but it only allows QCIF videos at 176x144. Trying any other resolution will either cause the phone to return an error or treat the file as if it is audio and play only that. I have done mucho searching in all the cell phone forums (Howard Forums, ESATO, SE-ENSE, etc) with no luck. Everyone seems to think it's impossible. I am very surprised that no one has come up with a patch or hack, since this model has been customized like crazy by the community. Anyway, the walkman player will rotate and stretch a 176x144 video to full screen, but of course, it looks like crap. I am assuming that if the phone can do this, it has the ability to play a 220x176 video landscaped.
My experiment is to try to trick the phone into thinking it has a 176x144, when it is really being presented with a 220x176 video, encoded at 90 degrees (effectively 176x220). I am using The Matrix, ripped from DVD to XVID AVI and AAC MP4A files. I used a program called ABC AVI Tag Editor to edit the AVI header to show 176x144. I checked with GSpot after, and it shows it is 176x144. The only problem is, when I mux the modified video and audio into an MP4, the final MP4 shows that it is 176x220. Does anyone know how I can make the outputted MP4 show a 176x144 frame size in the header? I can't seem to find any info or program on editing an MP4 header.
Any help would be greatly appreciated. Thanks!
Anyone know how to make an MP4 video show a different frame size in the header or stream, than the actual frame size?
Does your phone possibly only support x16 video sizes and thus you need to use 224 not 220 ?
Ooh, that's a good one. I'll try that and let you know.
When you go from hacked AVI (which contains the MP4 video and AAC audio) to actual MP4, you're stripping the hacked container and encapsulating the media into the new MP4 container. You can see this happen when you cross convert with YAMB/MP4BOX.
That's part of your problem, also as there can be flags/sectors in both the MP4 container and the elementary MP4 video stream that describe the video size, you may need to hack BOTH (although I'd try the elementary video stream 1st).
Also, QCIF is a standard, an MPEG "profile" if you will, and for ESPECIALLY embedded devices to work, they have to have content that conforms to that spec. So,...
Squeeze/Pad/Crop/Resize if you have to, but you'll probably end up having to leave it as-is. BTW, QCIF won't support anamorphic ARs, so its either fullscreen 4:3 style or hardcoded/padded 16:9 style, IMHO.
Can you edit mp4's with different frame height/width so that they merge?
By stiltsky in forum EditingReplies: 7Last Post: 30th Jul 2010, 00:36 -
Best software for Frame by Frame Video Edit?
By VEBouto in forum Newbie / General discussionsReplies: 5Last Post: 8th Feb 2010, 16:28 -
can you edit the header of an mpg file
By lmwashere in forum EditingReplies: 9Last Post: 13th Nov 2009, 21:07 -
Edit MP4 frame size metadata
By tb582 in forum Video ConversionReplies: 1Last Post: 24th Jun 2009, 22:13 -
Anyone know how to fudge the frame size in an MP4 header?
By Darney76 in forum Video ConversionReplies: 1Last Post: 23rd Dec 2007, 18:48
