Hi I'm seeking latest commandline settings for FFMPEG program and X264 program to produce ipod 5.5 mp4. Don't want to install dotNET, so no WinFF etc... need to roll-my own flags.
Any suggestions or links ?
So far I've located these (ffmpeg only) and can't decide what's "good"![]()
http://forum.videohelp.com/topic330839.html#1768385
Suggested Xvid iPod command line options.
ffmpeg -f mp4 -y -vcodec xvid -b 400k -qmax 10 -bufsize 4096 -g 300 -acodec aac -ab 96k -ac 2 -i "Path-to-input-file.avi" -s 320x180 -aspect 16:9 "Path-to-output-file.mp4"
BTW As you can see, this is for a wide screen input file. A full screen would be -s 320x240 -aspect 4:3
http://videotranscoding.wikispaces.c...deForIPodorPSP
Mpeg4 (old command line version, mind you):
ffmpeg -y -i <infile> -f mp4 -b 1000 -maxrate 1000 -vcodec xvid -qmin 3
-qmax 5 -s 480x480 -acodec aac -ab 128 <outfile>
H264 (old command line version, mind you):
ffmpeg -y -i <infile> -pass 1 -v 1 -vcodec h264 -b 400 -refs 1 -loop 1 -subq 1
-threads 2 -max_b_frames 0 -level 13 -g 300 -keyint_min 30 -qcomp 0.6 -qmax 35
-max_qdiff 4 -i_quant_factor 0.71428572 -b_quant_factor 0.76923078
-rc_max_rate 768 -rc_buffer_size 244 -cmp 1 -s 320x240 -acodec aac -ab 96
-ar 48000 -ac 2 -f mp4 /dev/null
ffmpeg -y -i <infile> -pass 2 -v 1 -vcodec h264 -b 400 -refs 5 -loop 1 -deblockalpha 0
-deblockbeta 0 -parti4x4 1 -partp8x8 1 -partb8x8 1 -me full -subq 6 -brdo 1
-me_range 21 -chroma 1 -threads 2 -slice 2 -max_b_frames 0 -level 13 -g 300
-keyint_min 30 -sc_threshold 40 -rc_eq 'blurCplx^(1-qComp)' -qcomp 0.6 -qmax 35
-ar 48000 -ac 2 -f mp4 <outfile>
http://rob.opendot.cl/index.php/usef...p-video-guide/
For one pass (newer commandline):
ffmpeg -i INPUT -acodec libfaac -ab 128k -ar 48000 -s WIDTHxHEIGHT -r FRAME_RATE -vcodec libx264 -b BIT_RATE -flags +loop -cmp +chroma -partitions +parti4x4+partp8x8+partb8x8 -me umh -subq 5 -trellis 1 -refs 2 -bf 1 -coder 1 -me_range 16 -g 300 -keyint_min 25 -sc_threshold 40 -i_qfactor 0.71 -bt BIT_RATE -maxrate 4M -bufsize 4M -rc_eq 'blurCplx^(1-qComp)' -qcomp 0.6 -qmin 10 -qmax 51 -qdiff 4 -level 21 OUTPUT.mp4
For two pass (newer commandline):
ffmpeg -i INPUT -an -pass 1 -s WIDTHxHEIGHT -r FRAME_RATE -vcodec libx264 -b BIT_RATE -flags +loop -cmp +chroma -partitions +parti4x4+partp8x8+partb8x8 -me dia -subq 1 -trellis 0 -refs 1 -bf 1 -b_strategy 1 -coder 1 -me_range 16 -g 300 -keyint_min 25 -sc_threshold 40 -i_qfactor 0.71 -bt BIT_RATE -maxrate 4k -bufsize 4k -rc_eq 'blurCplx^(1-qComp)' -qcomp 0.6 -qmin 10 -qmax 51 -qdiff 4 OUTPUT.mp4
ffmpeg -i INPUT -acodec libfaac -ab 128k -ar 48000 -pass 2 -s WIDTHxHEIGHT -r FRAME_RATE -vcodec libx264 -b BIT_RATE -flags +loop -cmp +chroma -partitions +parti4x4+partp8x8+partb8x8 -flags2 +mixed_refs -me umh -subq 5 -trellis 1 -refs 2 -bf 1 -b_strategy 1 -coder 1 -me_range 16 -g 300 -keyint_min 25 -sc_threshold 40 -i_qfactor 0.71 -bt BIT_RATE -maxrate 4k -bufsize 4k -rc_eq 'blurCplx^(1-qComp)' -qcomp 0.6 -qmin 10 -qmax 51 -qdiff 4 -level 21 OUTPUT.mp4
http://forum.videohelp.com/topic313899-30.html#1643797
if you want a video size of 320X240 you can use this:
Command0=""<%AppPath%>\cores\ffmpeg" -y -maxfr 30 -i "<%InputFile%>" -title "<%Title%>" -timestamp "<%TimeStamp%>" -bitexact -vcodec h264 -coder 0 -bufsize 256 -g 250 -vlevel 13 -fixaspect -s 320x240 -b 600 -maxrate 768 -qmin 2 -qmax 51 -passlogfile "<%OutputFile%>" -pass 1 -acodec aac -ac 2 -ar 48000 -ab 64 -f ipod "<%TemporaryFile%>.M4V""
Command1=""<%AppPath%>\cores\ffmpeg" -y -maxfr 30 -i "<%InputFile%>" -title "<%Title%>" -timestamp "<%TimeStamp%>" -bitexact -vcodec h264 -coder 0 -bufsize 256 -g 250 -vlevel 13 -fixaspect -s 320x240 -b 600 -maxrate 768 -qmin 2 -qmax 51 -passlogfile "<%OutputFile%>" -pass 2 -acodec aac -ac 2 -ar 48000 -ab 64 -f ipod "<%TemporaryFile%>.M4V""
Command2="rm "<%OutputFile%>-0.log""
Command3=""<%AppPath%>\cores\QT3GPPFlatten" "<%TemporaryFile%>.M4V" "<%TemporaryFile%>_2.M4V" -c QT_H264_QVGA_AAC.ini -t mpg4"
Command4="rm "<%TemporaryFile%>.M4V""
Command5=""<%AppPath%>\cores\ATOMChanger" "<%TemporaryFile%>_2.M4V" "<%OutputFile%>.M4V" "Camouflage_MOVIE_for_iPod.ini" "<%Title%>""
Command6="rm "<%TemporaryFile%>_2.M4V""
Command7=""<%AppPath%>\cores\AddiTunes" "<%OutputFile%>.M4V"
http://rob.opendot.cl/index.php/usef...d-video-guide/
1.5Mbit/s 640×480 H.264 videos (for improved quality using TV out)
For one pass:
ffmpeg -i INPUT -acodec libfaac -ab 128k -s WIDTHxHEIGHT -vcodec libx264 -b BIT_RATE -flags +loop -cmp +chroma -partitions +parti4x4+partp8x8+partb8x8 -me umh -subq 5 -trellis 1 -refs 1 -coder 0 -me_range 16 -g 300 -keyint_min 25 -sc_threshold 40 -i_qfactor 0.71 -bt BIT_RATE -maxrate 10M -bufsize 10M -rc_eq 'blurCplx^(1-qComp)' -qcomp 0.6 -qmin 10 -qmax 51 -qdiff 4 -level 30 -aspect WIDTH:HEIGHT OUTPUT.mp4
For two pass:
ffmpeg -i INPUT -an -pass 1 -s WIDTHxHEIGHT -vcodec libx264 -b BIT_RATE -flags +loop -cmp +chroma -partitions 0 -me epzs -subq 1 -trellis 0 -refs 1 -coder 0 -me_range 16 -g 300 -keyint_min 25 -sc_threshold 40 -i_qfactor 0.71 -bt BIT_RATE -maxrate 10M -bufsize 10M -rc_eq 'blurCplx^(1-qComp)' -qcomp 0.6 -qmin 10 -qmax 51 -qdiff 4 -level 30 -aspect WIDTH:HEIGHT OUTPUT.mp4
ffmpeg -i INPUT -acodec libfaac -ab 128k -pass 2 -s WIDTHxHEIGHT -vcodec libx264 -b BIT_RATE -flags +loop -cmp +chroma -partitions +parti4x4+partp8x8+partb8x8 -me umh -subq 5 -trellis 1 -refs 1 -coder 0 -me_range 16 -g 300 -keyint_min 25 -sc_threshold 40 -i_qfactor 0.71 -bt BIT_RATE -maxrate 10M -bufsize 10M -rc_eq 'blurCplx^(1-qComp)' -qcomp 0.6 -qmin 10 -qmax 51 -qdiff 4 -level 30 -aspect WIDTH:HEIGHT OUTPUT.mp4
768kbit/s 320×240 H.264 videos
For one pass:
ffmpeg -i INPUT -acodec libfaac -ab 128k -s WIDTHxHEIGHT -vcodec libx264 -b BIT_RATE -flags +loop -cmp +chroma -partitions +parti4x4+partp8x8+partb8x8 -flags2 +mixed_refs -me umh -subq 5 -trellis 1 -refs 5 -coder 0 -me_range 16 -g 250 -keyint_min 25 -sc_threshold 40 -i_qfactor 0.71 -bt BIT_RATE -maxrate 768k -bufsize 2M -rc_eq 'blurCplx^(1-qComp)' -qcomp 0.6 -qmin 10 -qmax 51 -qdiff 4 -level 13 -title SOME_TITLE OUTPUT.mp4
For two pass:
ffmpeg -i INPUT -an -pass 1 -s WIDTHxHEIGHT -vcodec libx264 -b BIT_RATE -flags +loop -cmp +chroma -partitions 0 -me epzs -subq 1 -trellis 0 -refs 1 -coder 0 -me_range 16 -g 250 -keyint_min 25 -sc_threshold 40 -i_qfactor 0.71 -bt BIT_RATE -maxrate 768k -bufsize 2M -rc_eq 'blurCplx^(1-qComp)' -qcomp 0.6 -qmin 10 -qmax 51 -qdiff 4 -level 13 -title SOME_TITLE OUTPUT.mp4
ffmpeg -i INPUT -acodec libfaac -ab 128k -pass 2 -s WIDTHxHEIGHT -vcodec libx264 -b BIT_RATE -flags +loop -cmp +chroma -partitions +parti4x4+partp8x8+partb8x8 -flags2 +mixed_refs -me umh -subq 5 -trellis 1 -refs 5 -coder 0 -me_range 16 -g 250 -keyint_min 25 -sc_threshold 40 -i_qfactor 0.71 -bt BIT_RATE -maxrate 768k -bufsize 2M -rc_eq 'blurCplx^(1-qComp)' -qcomp 0.6 -qmin 10 -qmax 51 -qdiff 4 -level 13 -title SOME_TITLE OUTPUT.mp4
2.5Mbit/s 640×480 MPEG-4 SP videos
For one pass:
ffmpeg -i INPUT -acodec libfaac -ab 128k -s WIDTHxHEIGHT -vcodec mpeg4 -b BIT_RATE -flags +aic+cbp+mv0+mv4+trell -mbd 2 -cmp 2 -subcmp 2 -g 250 -maxrate 2.5M -bufsize 2M -title SOME_TITLE OUTPUT.mp4
For two pass:
ffmpeg -i INPUT -an -pass 1 -s WIDTHxHEIGHT -vcodec mpeg4 -b BIT_RATE -flags +aic+cbp+mv0+mv4+trell -mbd 2 -cmp 2 -subcmp 2 -g 250 -maxrate 2.5M -bufsize 2M -title SOME_TITLE OUTPUT.mp4
ffmpeg -i INPUT -acodec libfaac -ab 128k -pass 2 -s WIDTHxHEIGHT -vcodec mpeg4 -b BIT_RATE -flags +aic+cbp+mv0+mv4+trell -mbd 2 -cmp 2 -subcmp 2 -g 250 -maxrate 2.5M -bufsize 2M -title SOME_TITLE OUTPUT.mp4
Cheers
The thing is, in the end,Originally Posted by halsboss
only you can.
It's unlikley someone will do your testing for you.
You have the material, the software and enough commandline options.
Now you need to find the time.
You seem to have plenty.Originally Posted by halsboss
Although you should probably just toss the old stuff, it's ancient.
Avanti has no net dependencies and is a good gui to roll with your own flags.Originally Posted by halsboss
You should try it out when it becomes available again.
gl
Thanks, yes, just wondered if others have firmer views. No responses for the X264 command line (I'd thought it could produce for ipod but an unsure). Oh well.Originally Posted by 45tripp
for Ipod 5.5 conversions to be viewed also on TV, I have the choice between 640x480 and ref=1 or 320x240 and ref=5 plus mixed refs.
Which means, I could probably go for 320x480 and ref=3 and mixed refs.
For the same bitrate (around 1.5 Mbps), will you go for 640x480 and ref =1 or 320x480 or 448x336 and ref=3 and mixed refs.
Thx
I remembered the Metadata must be repleaced by AtomicParsley if the video size larger than 320x240
MeGUI & x264 settings
By codemaster in forum DVD RippingReplies: 3Last Post: 17th Feb 2011, 13:07 -
add background music using ffMpeg or any commandline tool (free)
By Shohag_ifas in forum AudioReplies: 2Last Post: 21st Jan 2011, 06:25 -
X264 Color Matrix settings & others
By themaster1 in forum Video ConversionReplies: 1Last Post: 9th Sep 2009, 08:58 -
converting MOD to AVI to MP4 using avisynth, x264, mp4box & ffmpeg
By Wakewatcher in forum Video ConversionReplies: 3Last Post: 27th Dec 2008, 16:58 -
what ffmpeg commandline should I use ?
By halsboss in forum Video ConversionReplies: 2Last Post: 3rd Apr 2008, 04:49
